![]() | Home > Tdi > 200 tdi vs 300 tdi driving |
Dave k Member Since: 29 Feb 2012 Location: Cheshire Posts: 151 ![]() ![]() |
There's more spring assistance on the 300 tdi clutch.
I used to find the 200 clutch heavier although easier to drive in wellies. ![]() In my case, the 200 was in a Ninety, & 300 in a 110, so comparisons are difficult. Ex RN 110 Station Wagon Never Raced or Rallyed |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5353 ![]() ![]() |
so that explains the clutch pedal then, I think my dad thinks these two are the same, and is using mine as a base, Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
yostumpy Member Since: 01 Aug 2010 Location: n/kent Posts: 327 ![]() |
also the 300 will seemingly feel heavier to drive, nose diving into corners a tad more, due to the fact tat the 300 engine is a good ...ooo...probably 8" + / - further forward than the 200, which makes it all a bit nose heavy.
That will explain why mine is nose dives into corners than my dads 200. Also is the 200 more pokey than the 300? bare this in mind, I have a standard exhaust with a cat on, which has a slight blow. His has a custom made job with no cat. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11062 ![]() ![]() |
Procta why has your exhaust got a a cat on, no need for that on at that age
looks like its been on since the day it was built by the look of it, I need to find a decent pipe to replace it. My Peugeot 306 on a Y plate got the DEcat treatment some years ago now, and I tell you what, it made a massive difference in power! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
O, cant tell you the difference as mine has not got one but it has got a full SS exhaust that i put on it
where did you get that from? My dad got one made up for his, but has had nothing but trouble with it.
I know removing the EGR system did make a massive difference in performance, more lively in 1st and 2nd gear. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
Are you sure its a cat, and not just the flexi joint bit,, which is bigger diameter than the rest of the pipe .wouldn't have been a cat anyway, cats don't do anything on a diesel.
Sorry for the late reply Procta, i got my full SS exhaust from Double S, great service and fitted all ok and still going strong
Out of the factory, they produced the same power and torque (although the Defender 200tdi was detuned slightly compared to the Discovery 200tdi - only a couple of hp). The 300 was re-engineered to be more refined and the installation in both Defender and Discovery was the same. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
^^^ LRA didn't the auto Discovery have a few more hp than the manual Discovery ? Clayton.
Yeah, but only the 300tdi that was fitted with electronic diesel control. Power up to 122 from 111, IIRC. It made a noticeable difference too - the later auto was pretty spritely. Darren
CATs just strangle diesels, I found as soon as I removed mine on the Peugeot, the car was more responsive. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
