![]() | Home > Tdi > 200 tdi vs 300 tdi driving |
| Dave k Member Since: 29 Feb 2012 Location: Cheshire Posts: 151
There's more spring assistance on the 300 tdi clutch.
I used to find the 200 clutch heavier although easier to drive in wellies. In my case, the 200 was in a Ninety, & 300 in a 110, so comparisons are difficult. Ex RN 110 Station Wagon Never Raced or Rallyed |
| Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5347
so that explains the clutch pedal then, I think my dad thinks these two are the same, and is using mine as a base, Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
| yostumpy Member Since: 01 Aug 2010 Location: n/kent Posts: 327 |
also the 300 will seemingly feel heavier to drive, nose diving into corners a tad more, due to the fact tat the 300 engine is a good ...ooo...probably 8" + / - further forward than the 200, which makes it all a bit nose heavy.
That will explain why mine is nose dives into corners than my dads 200. Also is the 200 more pokey than the 300? bare this in mind, I have a standard exhaust with a cat on, which has a slight blow. His has a custom made job with no cat. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
| L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11049
Procta why has your exhaust got a a cat on, no need for that on at that age
looks like its been on since the day it was built by the look of it, I need to find a decent pipe to replace it. My Peugeot 306 on a Y plate got the DEcat treatment some years ago now, and I tell you what, it made a massive difference in power! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
O, cant tell you the difference as mine has not got one but it has got a full SS exhaust that i put on it
where did you get that from? My dad got one made up for his, but has had nothing but trouble with it.
I know removing the EGR system did make a massive difference in performance, more lively in 1st and 2nd gear. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
Are you sure its a cat, and not just the flexi joint bit,, which is bigger diameter than the rest of the pipe .wouldn't have been a cat anyway, cats don't do anything on a diesel.
Sorry for the late reply Procta, i got my full SS exhaust from Double S, great service and fitted all ok and still going strong
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
Out of the factory, they produced the same power and torque (although the Defender 200tdi was detuned slightly compared to the Discovery 200tdi - only a couple of hp). The 300 was re-engineered to be more refined and the installation in both Defender and Discovery was the same. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
^^^ LRA didn't the auto Discovery have a few more hp than the manual Discovery ? Clayton.
Yeah, but only the 300tdi that was fitted with electronic diesel control. Power up to 122 from 111, IIRC. It made a noticeable difference too - the later auto was pretty spritely. Darren
CATs just strangle diesels, I found as soon as I removed mine on the Peugeot, the car was more responsive. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
