![]() | Home > Td5 > TD5 - Fuel in the coolant! |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20939 ![]() ![]() |
Are you sure the fuel cooler pipes are the right way around?
On the Puma the two are right next to one another, not sure about the TD5? So you have diesel and coolant passing through, in separate pipes right next to one another. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Tank Member Since: 25 Jul 2014 Location: Fife Posts: 431 ![]() ![]() ![]() |
Hope so it was fitted by Gem 4x4 a Land Rover specialist!
Anyone got an idea?
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
Td5 runs an internal fuel rail in the head. Worst case it could be a cracked head or head gasket. 2002 90 Td5 Station Wagon
Would there not be other symptoms?
How would I suss that out? |
I think a pressure test would be a good option
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
If you've replaced everything where fuel and coolant interact then there isn't much else it could be I wouldn't have thought? 2002 90 Td5 Station Wagon
So what's a new cyclinder head gona cost?
Around £1000+vat but I think there is possibly some more investigation to be done first. I'm only going on a hunch
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17911 ![]() ![]() ![]() |
If the 'O' rings in the cooler haven't been correctly fitted it may still be leaking.
Cheers, will take it back to the garage next week! Hope its that!
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 567 ![]() ![]() ![]() |
Did it have a new fuel cooler or seals replaced? The seals only stop coolant leaking to atmosphere, inside there is tubes which the fuels flows around, these are welded stainless which could possibly crack.
When the seals on the injectors leak you would expect oils level rising. Kind Regards Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88β 2A 200tdi 2002 110 Hardtop |
It had a brand new fuel cooler fitted?
CDN38 Member Since: 14 Nov 2014 Location: Courtenay, BC Posts: 729 ![]() ![]() ![]() |
Are you 100% sure it's fuel in the coolant, not oil? it's a Landrover thing...
my renovation thread: http://www.defender2.net/forum/topic40792.html |
