Home > Td5 > TD5 - Fuel in the coolant!
Tank
Scotland 2004 Defender 90 Td5 HT Zermatt Silver
Ok cleaver people! Question.
I have a 2004 TD5 and have diesel in the coolant system! How?
I have changed the fuel cooler and the fuel regulator and thought that would do the trick, but no!
How else can fuel get into the coolant system.
Any advice greatly received Smile
Thanks
Duncan
Post #634707 30th Jun 2017 5:03pm
Are you sure the fuel cooler pipes are the right way around?
On the Puma the two are right next to one another, not sure about the TD5?
So you have diesel and coolant passing through, in separate pipes right next to one another. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #634710 30th Jun 2017 5:13pm
Tank
Hope so it was fitted by Gem 4x4 a Land Rover specialist!
Post #634712 30th Jun 2017 5:16pm
Tank
Anyone got an idea?
Post #634788 30th Jun 2017 9:43pm
grafty99
Td5 runs an internal fuel rail in the head. Worst case it could be a cracked head or head gasket. 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #634792 30th Jun 2017 9:59pm
Tank
Would there not be other symptoms?
How would I suss that out?
Post #634793 30th Jun 2017 10:03pm
grafty99
I think a pressure test would be a good option Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #634795 30th Jun 2017 10:08pm
grafty99
If you've replaced everything where fuel and coolant interact then there isn't much else it could be I wouldn't have thought? 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #634796 30th Jun 2017 10:09pm
Tank
So what's a new cyclinder head gona cost?
Post #634798 30th Jun 2017 10:22pm
grafty99
Around £1000+vat but I think there is possibly some more investigation to be done first. I'm only going on a hunch Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #634802 30th Jun 2017 10:36pm
If the 'O' rings in the cooler haven't been correctly fitted it may still be leaking.
Post #634807 30th Jun 2017 10:46pm
Tank
Cheers, will take it back to the garage next week! Hope its that!
Post #634810 30th Jun 2017 11:01pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
Did it have a new fuel cooler or seals replaced? The seals only stop coolant leaking to atmosphere, inside there is tubes which the fuels flows around, these are welded stainless which could possibly crack.
When the seals on the injectors leak you would expect oils level rising.
Kind Regards
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #634814 30th Jun 2017 11:23pm
Tank
It had a brand new fuel cooler fitted?
Post #634824 1st Jul 2017 4:12am
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
Are you 100% sure it's fuel in the coolant, not oil? it's a Landrover thing...
my renovation thread:
http://www.defender2.net/forum/topic40792.html
Post #634916 1st Jul 2017 4:56pm
