Home > Maintenance & Modifications > Advice on sealant for roof
ChrisDefender
Hi,
I seem to have developed a leak from somewhere on the roof I think.
When it has been a very heavy rainfall when I open the door and drive off, water runs down the inner of the A pillar from behind the plastic trim, so I presume I must have a small crack somewhere? Occassionally a few drops appear on the sun visors too when they are in the down position.
I cannot see anything obvious from the outside.
I plan to remove the headlining and put some sealant in along the joins. I presume this is the right thing to do?
Is the best stuff to use the Sikaflex 252 Structural Sealand & Adhesive, as I have seen mentioned on the forum before.
Any help appreciated as I hve never done anything like this before.
Cheers all.
Post #634345 29th Jun 2017 11:35am
Paddie42
England 2003 Defender 110 Td5 SW Belize Green
I had the same problem on both sides. I used Captain Tolley's creeping crack cure. Several weeks with the headling removed and this stuff and no more leaks.
Thumbs Up
Post #634390 29th Jun 2017 2:50pm
ChrisDefender
Hi,
Great, thank you very much. That looks like it would do the trick.
Cheers.
Post #634425 29th Jun 2017 5:24pm
Scott_Landy
United Kingdom 1993 Defender 110 200 Tdi CSW Firenze Red
My experience of Captain Tolleys is that is is very good on fine cracks as it's a very watery consistency which means it gets into cracks with a capillary action. Larger cracks may need something with a thicker consistency. Just a thought!
Post #634753 30th Jun 2017 7:52pm
