![]() | Home > Maintenance & Modifications > Transfer box output seal renewal |
Have you done this job on the drive. yes
Was I just unlucky with the first one in that it was so tight? no Was thinking of getting a cordless impact driver, half inch, but not confident that it will have the torque shock to loosen. if hold drive flange with flat bar and bolts LRT-51-003 http://www.defender2.net/forum/topic54335.html front and back flanges are different tighten up 20mm nut (162Nm ) for TDI 300 defender transfer box Last edited by dorsetsmith on 29th Jun 2017 9:41am. Edited 1 time in total |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17874 ![]() ![]() ![]() |
I have done it on the drive (more than once) and never had trouble with the flange nuts.
Do you have a suitable tool to hold the flange when you undo the nut? |
dioliahary Member Since: 18 Jan 2015 Location: Manchester Posts: 668 ![]() ![]() |
No unfortunately
Take a length of flat bar or angle of a suitable length and drill two holes to fit over the flange bolts, making sure, of course, that you can still get to the retaining nut.
It is much easier to remove the nut if you can hold the flange completely stationary. |
Good news, broke the nut loose however the seal does not seem right, I have retrofitted the transfer box to a Discovery transfer box.
Too late to take a picture but there seems to be a cup which requires removing before the seal can be flipped out... ![]() |
I think it's a oil catcher/ dust catcher, does it knock off
yes have look below
https://forums.lr4x4.com/topic/29370-repla...-oil-seal/ |
Spot on, thanks will finish off tonight
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1247 ![]() ![]() ![]() |
I've not had experience of this particular job but for those questioning whether an impact hammer will have enough grunt to undo it. Depends on the model but almost certainly. I've got a Milwaukee 1/2" impact hammer and that's truly astonishing what it will undo (rated to 1600+Nm for undoing nuts).
Two examples of what it's capable of: 1. Colleague at work borrowed it to get the wheel nuts off his TE20 tractor, he'd managed to bend a 1/2" breaker bar and scaffolding pole in previous attempts. Tried the low torque setting, nothing. High torque and nut simply spun straight off with very little resistance he said. 2. I had a split pin snap on me on the anti-roll bar on the Defender as the centre was seized in I couldn't be bothered to drill it out so thought what the hell... Whacked a socket over the top of it, put the impact hammer on it and it didn't break a sweat (don't think it even used the impact bit, simply the torque from the motor) and sheered the rest of the pin internally and spun the nut off. Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
It depends on the gun, the cheap anybrand ones possibly not, but i have a large Dewalt 18v one and that thing with snap M8 bolts like they're made from chocolate. It has imense amounts of torque and will either undo or sheer off any fixing you'll find on a Defender. Another way might do it, is chock the wheels, disconnect both props, and engage diff lock. Put a socket and long bar on the nut and wedge it against the revolution either against the floor or the chassis rail. Then stick it in gear and use the starter to crack it off. |
