![]() | Home > Technical > Oil drip on handbrake drum |
The job entails
STC3433 Kit-flange,Rear ![]() and one of these in stead as the kit seal will be unbranded unless you go for (LR) ![]() rear prop removed 9/16 AF ring spanner and or http://www.paddockspares.com/da1119-propsh...50gbp.html back off brake shoes 17mm open ended spanner remove brake drum may be healed in place with 8mm countersink screw ![]() drain transfer box oil remover 20mm nut from flange and remover rear flange remover old oil seal refit new oil seal down to its home on the shoulder (also run small amount of grease in the seal before fitting it) ![]() having removed [ 3/8UNF x 1 3/4 ]bolts from the old flange and fitted them to the new one with new mud shield or use new FRC3602 [ 3/8UNF x 1 3/4 ]bolts fit new drive flange felt washer, plane washer and nut tighten up nut (148Nm or 109 ft-lb ) 2.4 defender > 07 refill transfer box oil EP 80/90 clean brake shoes and assemble with brake cleaning or ( replace brake shoes ) replace brake drum and adjust shoes also then all is finished teat handbrake refit prop shaft new nuts NZ606041L [ UNF - 3/8 nylocks ] X 8 make shore transfer box breve pipe is not blocked ![]() have fun Next Last edited by dorsetsmith on 8th May 2017 9:08am. Edited 1 time in total |
Leviathan Member Since: 24 Oct 2015 Location: Staffs Posts: 248 ![]() ![]() |
Thats exactly what I was after DS.
You're a star. Nick |
Peter Td4 Member Since: 23 Oct 2010 Location: Antwerp, Belgium Posts: 228 ![]() ![]() ![]() |
Excellent info, thanks
![]() I also have this planned soon. Peter, Defender 110 StaWa - Td5 Defender 110 HCPU - Puma Defender 90 Soft Top - Td5 |
Just had a go at this and on removal of the handbrake drum found its bone dry inside.
Assuming the seal kit mentioned here isnt leaking I replaced the drum and reconnected the prop. So thing is, should I have replaced the seal or is it leaking from a different area? BTW if you are going to do this make sure you have some new 9/16 nyloc nuts ready because the old ones are a b*gg*r to get off and will be rounded. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17876 ![]() ![]() ![]() |
They're 3/8" UNF Nylocs.
Sorry yes of course 3/8" UNF. I used a 9/16 spanner and that was in my head
Bushpig Member Since: 07 Nov 2013 Location: Risca, Wales Posts: 236 ![]() ![]() ![]() |
Perhaps look at the intermediate shaft seal? It is on the front of the T/box.
I too had a leaking T/box that was dripping onto the handbrake drum, but not inside. It was a box out job and ended up replacing the intermediate shaft also... Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so. Douglas Adams 2012 2.2 Puma |
I'll wait until something else goes in that area then.
![]() Its not that bad atm. |
