![]() | Home > Maintenance & Modifications > Megga Prop (front) |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
Is it the prop that cured the vibrations or the dealer what have they done
All the dealer has done so far is a 24k service, not touched the 'issues' yet, however now there are less issues.
Can you get the props balanced .
Waiting to be given purchase history then I will know whats what
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 764 ![]() ![]() ![]() |
I thought that this kind of props were only usefull if we had a lifted supension...
What is the advantage of having one of these ? ... besides ending the vibrations ? Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
I have a lift
oops ! ![]() Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
Hi Andrews what make prop is it and what lift do you have bought the equipe one for my truck cost a fortune but it certainly works
Steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6198 ![]() ![]() ![]() |
^^^ I agree, i've got an equippe one here (off of my old 30Tdi), going to cut & shut it to fit the project90-3 (Td5).
It made the world of difference to vibrations, and is a well made bit of kit. |
I think its a "Megga" prop from Italy, Got it from devon 4x4 at a cost of about £400 130's have feeling's as well you know
Sounds to me like the new Bailey Morris prop the joint is from Italy the same as equipes
Nice bit of kit Regards steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17876 ![]() ![]() ![]() |
Is the DC joint on your new prop fully greasable and servicable? I am sure that the UJs are greasable, but is there a nipple for the centre bearing?
The DC joint on the Disco 2 is reckoned to be a notorious weak spot and if it fails catastophically can do £££ of damage to the car. I rebuilt a spare shaft with components from the States to provice larger UJs and full serviceability ready to fit to my Disco 2 but actually haven't yet had to fit it, and my original has done 200k miles. My Disco is a TD5 however, and I think the root cause of the reported propshaft failures is that on the V8 version the grease bakes out of the joints. I still think it was barmy to supply propshafts with "sealed for life" UJs though (but at the same time LR was building cars with no centre diff, so clearly the firm was going through a bad spell). On a Puma the propshaft is that bit nearer the exhaust (and if you haven't removed it) the cat, and I wonder if there may be a similar problem. |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2478 ![]() ![]() ![]() |
I have a toyota high angle CV jointed and it is a sweat. Fully greasable including the "hidden" central bearing.
Make sure you get a proper angle alignment between the diff flange and front end of the propshaft (ie. 0-3º max). Puma 110" SW ............................................................. Earth first. Other planets later |
