Home > Maintenance & Modifications > Height - Effect of Tyre Size / Lowering Springs?
Mr Fox
United Kingdom 2015 Defender 90 Puma 2.2 HT Keswick Green
Well, I know what my first mod is going to have to be... something to get the soft top lower!
So a question for the more knowledgeable:-
My previous 90 was a SW and was just a little too high to clear my garage door (overhead electric kind) - I solved this by parking it outside or when I wanted to get it into the garage, using two, full, 20 gallon water containers, placed in the rear load area, to load the suspension enough to drop it and clear the doors.
Yesterday I went to park the soft top in the garage and it also doesn't clear and it took three 20 gallon containers and Jr Fox sitting in the back to get it low enough to just clear the open door. It seems higher than the SW and I'm not sure if that is because of the Safety Devices hood cage or a combination of things.
The SW was on stock Sawtooths with whatever tyres came as standard.
The Soft Top is on the Dual Finish alloys with Goodyear Wrangler T/R 235/85R16. Does anyone know whether these would be effecting the ride height? Are they stock or larger? The speedo is off but not by a lot; therefore, I'm guessing that this is close to a stock set up (if not stock!).
My plan has always been to replace the Dual Finish with Wolf Wheels to get back to a more classic look but I don't want to throw the rolling radius off too much; however, that could help me lower the vehicle a little.
The quickest solution is to put some comfort lowering springs on but I'm not even sure 1" lower would be enough.
Any advice, comments and ideas welcome. Question
Post #632582 21st Jun 2017 8:41am
The tyres are a standard size and, as near as makes no odds, the same height as the ones on your previous SW (which are also a standard offering).
Fitting Wolf wheels won't make any difference as they're still 16 inch rims. It's the tyres you fit to them that can change, although whether you go for either of the typical 7.50's or 235.85, they're all the same height.
The main reason that your soft top is higher is just because it's a lot lighter than a SW, although the soft top frame might be slightly taller than a hardtop. Darren
Post #632590 21st Jun 2017 9:29am
mk1collector
It's probably a bit higher because you've lost the weight of the roof and side panels with glass. If you don't need it for any serious off roading then a little lowering won't make a big difference, maybe 1 or 2 inch. Over time the springs will settle a little too.
Edit: beaten to it Ray
My build thread
Post #632591 21st Jun 2017 9:32am
Mr Fox
Thanks guys, those were my assumption as well and Darren, cheers for confirming the stock rim/tyre setup.
I've dropped Coil Springs and email and hopefully I can get a set of springs on it rapidly; having a team of Umpa Lumpas jump in the back each time I want to get in or out of the garage isn't ideal.
Post #632592 21st Jun 2017 9:38am
Profyaffle
Or you could change your garage door Laughing
I changed mine from an up and over electric to a roller door, lots more room and supposedly more secure. 1993 200Tdi Defender 90
Post #632595 21st Jun 2017 9:50am
Mr Fox
Coil Springs are a 5-week lead time.
Alive are expecting their next batch of 'Comfort Lowering' in 5-weeks.
So two dead-ends there.
I know Urban Truck offer them but, being picky, they are red... ugh. Like putting diamonds on a hammer.
Post #632600 21st Jun 2017 10:30am
L90Andy
United Kingdom 1997 Defender 90 300 Tdi ST Nato Green
Sounds like you're making progress on a solution, but another one could be have a set of spare wheels with smaller diameter tyres on (205x80r16 - SWB basic standard size) which will gain you back ~35mm clearance - just swap them over and it should go in easier.
FYI, the above reasons for the soft top being higher are all valid, but not mentioned yet is the soft top frame is higher than a hard top as its a constant curve at the top to keep the rain from pooling.
BTW, I'm going through the same issue and am changing my up and over garage door to swing out barn style doors... Instagram: L90andy
My 1984 Ninety: http://www.defender2.net/forum/topic56071.html - SOLD!
My 2015 Defender: http://www.defender2.net/forum/topic39625.html - SOLD!
Post #632604 21st Jun 2017 10:40am
I would change the door.
Mods to the vehicle will alter the essential character too much.
You could always remove the soft top and sticks to put it away, but it is a bit of a hassle on the later models.
(I had a problem once in my 80" when I took a load of concrete rubble to the local tip and found, after unloading, that I no longer fitted under the barrier at the entrance/exit, to the great delight of the other tip users. Fortunately on an 80" it takes very little time indeed to remove the ragtop and drop the sticks.)
Post #632606 21st Jun 2017 10:50am
Mr Fox
Cheers Andy.
The garage is relatively new and is a double garage (two separate doors), so changing them isn't on the cards.
UT do have the springs in stock, so I could go that route; however, although they call them "progressive", after chatting with them, they definitely won't make the ride more comfortable and probably border on the performance side. As the CD player was skipping on the standard set up, I'm not aiming to make the ride harsher.
Does anyone know of any other company who sell 'lowering springs' with a comfort bias?
Post #632607 21st Jun 2017 10:52am
JOW240725
Might be of interest?
http://www.defender2.net/forum/topic53769.html?highlight=springs
http://www.defender2.net/forum/topic49065.html www.coilsprings.co.uk
However be aware lowering/comfort springs may effect ability to tow or carry heavy loads? James
Instagram @suffolk_rovers
Post #632609 21st Jun 2017 11:12am
gabe3105
If you have deep pockets, air suspension could be fitted which will give you an "access height" at the touch of a button. I think its circa £3-4k though!
Post #632610 21st Jun 2017 11:21am
Mr Fox
Cheers James. Thumbs Up
The first link are to the Extreme 4x4 springs, which are an option.
Your second link is to Coil Springs, who are the idea solution but as per my comment above, having spoken with them, they have a 5-week lead time.
I've made a few more phone calls and at the moment, the UT ones are looking like the best option.
Post #632612 21st Jun 2017 11:23am
Another solution, even if only temporary, would be another 20l water container. Darren
Post #632618 21st Jun 2017 11:57am
Mr Fox
I used to have a massive fish tank, so I have another 20 gallon container - it is definitely the short term solution. I may end up with arms like Popeye but it is doable Mr. Green
Post #632622 21st Jun 2017 12:48pm
How about a pond liner in the back, then fill from hosepipe until it will fit in the garage!
Post #632625 21st Jun 2017 12:58pm
