Home > Off Topic > Welding & ECU's...
Bushpig
Wales 2012 Defender 110 Puma 2.2 SW Alpine White
Welding & ECU's...
I'm cleaning up my bullbar, from many bush excursions and a small amount of welding is required...
With my old Tdi, it was a simple task of removing the battery terminals, but should I be concerned about the ECU (& or other electronics) on the TDCI?
With the steering guard & the wee bit of welding, it's not worth removing the whole bullbar.
Thanks in advance Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so.
Douglas Adams
2012 2.2 Puma
Post #631327 14th Jun 2017 2:18pm
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
I'm never sure of the official answer but I normally unplug the ECU to be safe although it's very probably totally unnecessary but better safe than sorry !
Making sure you have a good earth via your welding clamp close to where you are welding is always a good idea too as it helps localise the welding currents. http://www.yorkshireoffroadclub.net/
Post #631353 14th Jun 2017 5:08pm
Procta
When I have had a car welded, they have just removed the battery. If you remove the ECU, check that you don't trip anything like the inerter switch or what ever its called. I have removed ECUs and that fuel switch thing has always tripped. Just a case of pressing the Censored and all is well again. but that could have been down to a few things. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #631354 14th Jun 2017 5:16pm
