![]() | Home > Technical > Rough cold idle - what's the diagnosis? |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4332 ![]() ![]() ![]() |
That looks rock solid to me. Mine was up and down, nearly stalling. 2007 110 TDCi Station Wagon XS
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2680 ![]() ![]() ![]() |
yeah, unfortunately by the time I got to my phone, it had stopped doing it.
Will monitor over the next few days, this is the first time ever that it has done something like this. I estimate that the revs were going up by about 200-500rpm -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Shot Steve, will do that
![]() I've actually need quite lazy, I used to inspect/clean these every month, but haven't for a while. ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20978 ![]() ![]() |
Mine wasn't cleaned for years.
![]() Just didn't know anything much about it until recently with the wealth of knowledge here. Worth a go anyway. ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
captured some data yesterday at idle (hot) and 2000rpm. Do these look normal?
![]() Click image to enlarge ![]() Click image to enlarge -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Finally got around to doing some checks on the car today.
Both the MAP and MAF were clean, no real gunk to speak of on either. So I'll put it down to some dirt pickup due to having run the previous tank very low. I will make a note to tell my indie to drop & clean the tank and the next oil change in August, -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
damn, it did it again this morning, ambient was 14C.
I can rule out the diesel as this was a different tank from a different petrol station. what now? ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
Change your VCV valve!
I had exactly the same symptoms over the winter. You need to read live data when it's cold to get the fluctuations a bad VCV would give, It should be all over the place on cold start up, getting better as it warms up. 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
As it's persistent, it could well be the VCV as suggested above.
None the less, it was worth cleaning the MAF & MAP sensors. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
yep, it did it again this morning.
Skip to 29s in the video: -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Jerry Member Since: 13 Nov 2015 Location: Cardiff Posts: 213 ![]() ![]() |
could it be the grade of diesel - see this thread?
http://www.defender2.net/forum/topic55077.html |
I thought it may have been, but this is a new tank from a different brand.
previous tank was BP, this is Caltex, both 50ppm. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
gents, which live values should I be monitoring to diagnose if it is the VCV?
fuel rail pressure? -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Nevillerover Member Since: 14 Feb 2015 Location: Suffolk Posts: 224 ![]() ![]() ![]() |
My 2.4 has symptoms which according to other threads is VCV, hunting, lacklustre feel, rough cold idle, so I reckon at around £40 a new VCV is worth a try.
However, I've only got an icarsoft i810 obd computer thing and I don't know if that will do the re-learn. What happens if I don't do the learn, does it eventually learn itself over a number of miles? |
