Home > Technical > Help, lights stopped working on a night time drive!
ukmiitchellx
Mid way through a short drive earlier my lights decided to flash then die. The problem I have is:
when the light switch is all the way forward I get nothing at all, no low beam, no side lights and no main beam, but I can make the head lights flash by pulling the indictaor stalk towards me but can't turn them on by pushing it forward.
When the light switch is in the middle position I get side lights and very dim low beam, and again I can flash headlights with the stalk but if I push the indicator stalk forward everything goes off.
Any clue on what's gone wrong?
Thanks, Ben 1995 300TDi Hardtop Nato Green
Post #628804 3rd Jun 2017 11:29pm
topless_matt
England 2007 Defender 90 Puma 2.4 HT Tonga Green
Main light switch has melted the plastic housing causing contacts to not connect. Cheap 10 min fix
Post #628805 3rd Jun 2017 11:45pm
Bridge the switch. If you can as a temp measure. Then sort ASAP. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #628810 4th Jun 2017 12:08am
Mo Murphy
Yup, time for a new light switch. You can prevent reoccurrence of this by fitting one of the relayed headlamp harnesses, eliminating the high current flow through the switch.
HTH
50 Shades of Pennine Grey
Post #628811 4th Jun 2017 12:10am
ukmiitchellx
Cheers guys! I've gotta say it wasn't a fun drive home 1995 300TDi Hardtop Nato Green
Post #628842 4th Jun 2017 8:33am
ChrisWoods
United Kingdom 2009 Defender 110 Puma 2.4 USW Aintree Green
What I did was temporarily swapped the connectors around so the sidelight position powered the headlights. Gets you home safe. 2009 2.4TDCi XS Utility Wagon.
Post #628891 4th Jun 2017 2:47pm
Fatbaron
Just had this happen to me. The advice on here was superb! I checked the bulbs and fuses, replaced the switch, bridged the dim/dip relay but in the end it turned out to be a burnt relay.
Post #630668 12th Jun 2017 6:41am
