![]() | Home > Technical > Help, lights stopped working on a night time drive! |
ukmiitchellx Member Since: 04 Jan 2017 Location: Cornwall Posts: 27 ![]() ![]() |
Mid way through a short drive earlier my lights decided to flash then die. The problem I have is:
when the light switch is all the way forward I get nothing at all, no low beam, no side lights and no main beam, but I can make the head lights flash by pulling the indictaor stalk towards me but can't turn them on by pushing it forward. When the light switch is in the middle position I get side lights and very dim low beam, and again I can flash headlights with the stalk but if I push the indicator stalk forward everything goes off. Any clue on what's gone wrong? Thanks, Ben 1995 300TDi Hardtop Nato Green |
topless_matt Member Since: 29 Mar 2015 Location: norfolk Posts: 68 ![]() ![]() ![]() |
Main light switch has melted the plastic housing causing contacts to not connect. Cheap 10 min fix
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2362 ![]() ![]() ![]() |
Yup, time for a new light switch. You can prevent reoccurrence of this by fitting one of the relayed headlamp harnesses, eliminating the high current flow through the switch.
HTH Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
Cheers guys! I've gotta say it wasn't a fun drive home 1995 300TDi Hardtop Nato Green
ChrisWoods Member Since: 29 Dec 2016 Location: Spreyton Posts: 164 ![]() ![]() ![]() |
What I did was temporarily swapped the connectors around so the sidelight position powered the headlights. Gets you home safe. 2009 2.4TDCi XS Utility Wagon.
Fatbaron Member Since: 12 Mar 2016 Location: Devon Posts: 299 ![]() ![]() |
Just had this happen to me. The advice on here was superb! I checked the bulbs and fuses, replaced the switch, bridged the dim/dip relay but in the end it turned out to be a burnt relay.
