Home > Puma (Tdci) > Black smoke and gas pedal delay
Vesku
Finland 2007 Defender 110 Puma 2.4 XS CSW Zermatt Silver
Hi!
My -07 puma has a delay on gas pedal and smokes little (black) when accelerate.
EGR changed last week but that does't solve problem.
When I removed egr connector car works fine.
MIL light is on now.
Local LR service reset MIL light and found no error codes.
80000km on clock. My car is not remapped. Yet.
What next?
Post #630391 10th Jun 2017 3:51pm
lohr500
I'm no expert but could it be a split or disconnected turbo hose?
Post #630425 10th Jun 2017 5:41pm
Vesku
Thanks
But when EGR plug is disconnected the car runs fine without any smoke and delay..
Post #630484 11th Jun 2017 4:04am
Lightningtweeds
Scotland 2008 Defender 90 Puma 2.4 CSW Stornoway Grey
MAF sensor?
Post #630500 11th Jun 2017 7:28am
Vesku
I have cleaned the MAF and MAP sensors.
Post #630525 11th Jun 2017 11:00am
Lightningtweeds
They do fail.
Post #630526 11th Jun 2017 11:08am
Check wiring of EGR plug, check for signs of wear and crackin / splits ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #630527 11th Jun 2017 11:09am
v8bobber
United Kingdom 2008 Defender 110 Puma 2.4 DCPU Java Black
I've been having the same problem. There are no fault codes showing probably because electronically the system is fine, in that the signals are being sent to the egr but what happens after that, is maybe not correct.
If you have replaced the egr then there may be a break in the pipe (it's metal from memory) which is after the egr itself.
Ive fitted an egr blanking plate on mine but haven't tried it yet as I decided to change a couple of ball joints and do some other jobs while I was as it. This will put the warning light on but have the kit to reset it.
The blanking kits are only a few quid and can eliminate any issues after the egr.
If you can wait a week or so let me put mine back together I'll let you know how I get on!
Post #630541 11th Jun 2017 12:45pm
Vesku
Thank you.
I'll wait.
Can I unplug MAF sensor to test its condition?
Post #630984 13th Jun 2017 8:40am
Vesku
Hello
ECU program is now updated by LR service. Still smokes and little power loss when accelerate.
What next?
Post #631882 16th Jun 2017 8:41pm
Vesku
Problem solved by my self.
Turbo hose was slipped.
Post #631955 17th Jun 2017 5:17pm
lohr500
Thumbs Up As I suspected.
Post #631958 17th Jun 2017 5:29pm
Vesku
Yes. Thank you sir!
Post #631961 17th Jun 2017 5:32pm
Vesku
I drove a little longer testdrive and it smokes again. Not so much but still smokes when accelerating.
Post #632067 18th Jun 2017 10:43am
mk1collector
Split intercooler? Ray
My build thread
Post #632069 18th Jun 2017 10:54am
