Home > Puma (Tdci) > Black smoke and gas pedal delay
Page 2 of 2 <12
v8bobber
United Kingdom 2008 Defender 110 Puma 2.4 DCPU Java Black
Put the blanking plate in and wasn't any better. After you'd said that when you unplugged yours it ran fine I did the same but no difference.
I have had this error code.......
Which I haven't seen before so have changed the actuator for one I had lying around but haven't had chance to drive it yet.
Was talking to a friend with a 2.2 and the arm on theirs seems to move a lot more
Post #632522 20th Jun 2017 9:36pm
Vesku
Finland 2007 Defender 110 Puma 2.4 XS CSW Zermatt Silver
Ok.
Don't know the fault code number but LR service found that ECU box is broken.
They will try an new ECU some day soon I hope.
And no smoke when egr connector unplugged.
Post #632555 20th Jun 2017 10:54pm
Vesku
Can this cause my problem?
https://goo.gl/photos/TpsKdiBXM2mD57rF8
Post #632770 22nd Jun 2017 6:53am
v8bobber
Hi again,
Have a look at this topic I just posted....
Post #632806 22nd Jun 2017 10:11am
v8bobber
Post #632810 22nd Jun 2017 10:22am
Vesku
I'm going to remap on monday. Bye bye EGR..
Hope that will finally solve my problems.
Post #636256 7th Jul 2017 6:08pm
v8bobber
Let us know how you get on. I'm starting to think that my problem is possibly based around the ECU. If the local dealership ever give it back I might be able to investigate a bit more
Post #636277 7th Jul 2017 8:26pm
Vesku
So I have remapped my car and EGR is taken off
Engine runs well but still there is a visible black smoke sometimes when accelerating 4 and 5th gear.
I'll put planking plate on thursday so let see what happens then.
Post #636888 11th Jul 2017 7:19am
Vesku
And there was a hole in hose!
Just ordered siliconehoses and a bigger cooler😀
Post #641050 1st Aug 2017 5:48am
Petrovich
Russia
Vesku - your are the lucky one!
My 110 still rattling and black smoking when accelerate
After MAF changed, EGR and gaskets revised, turbine's hose pipes inspected
Officials says that turbine need to be changed or restored. But ! Oil level still stays normal and that why I'm confused
Cos if turbine makes problem - oil level should be lowering (I've been told) ... Defender 110 '07
Post #651220 19th Sep 2017 10:00am
Vesku
Local LR service checked intercooler/turbohoses but they could not find any damage there.
So I checked those pipes again and there it was. A 3cm long cut on cooler pipe.
Ordered silicone ones and a Serck cooler and now my defender flies!
Post #651233 19th Sep 2017 10:30am
Petrovich
Russia
Gotcha !
Did your turbine was rattling when you accelerate on the road as well ? Defender 110 '07
Post #651252 19th Sep 2017 11:49am
Page 2 of 2 <12
