Home > In Car Electronics > AMP connector - crimping
huffhuff
United Kingdom 2001 Defender 90 Td5 HT Java Black
Hi all,
I have the below plug/socket. What is the best method of crimping? Buying a specific tool? If so, what and where? Or will a squish with pliers work? Worth a dab of solder?
Cheers in advance
 TD5 Defender 90
Discovery 3 HSE
Post #630331 10th Jun 2017 11:59am
JustFX
United Kingdom 2000 Defender 110 Td5 CSW Coniston Green
A ratchet crimp tool for Uninsulated crimps should do the job. I bought a set with interchangeable anvils so I can use them for a variety of projects.
Something like this would do,
http://www.ebay.co.uk/itm/182613942170
The Connectors can be found on the bay for a few quid for 10 or so. Just have to wait for China delivery times.
Post #630339 10th Jun 2017 12:13pm
huffhuff
Thanks. I have the usual red, blue and yellow ratchet crimper. Will dig it out and see if the anvils can be changed Smile
Cheers TD5 Defender 90
Discovery 3 HSE
Post #630341 10th Jun 2017 12:17pm
A pair of needlenose pliers would do the job just right.
Thumbs Up _\Hennessey|Venom| F5/___
___\â­ï¸Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_
Post #630346 10th Jun 2017 12:37pm
VeeTee
Netherlands
^ A special crimp tool like in the link from JustFX will do much better than a pair of needle nose pliers...
I'll get my coat.... Whistle Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #630350 10th Jun 2017 12:47pm
Bushpig
Wales 2012 Defender 110 Puma 2.2 SW Alpine White
Thumbs Up
Indeed Steve, much much cheaper than the more specialized crimpers.
Done all of mine with pliers Thumbs Up Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so.
Douglas Adams
2012 2.2 Puma
Post #630358 10th Jun 2017 1:22pm
huffhuff
Cheers all. Pliers it is Smile TD5 Defender 90
Discovery 3 HSE
Post #630369 10th Jun 2017 2:27pm
Thon
If you want the connector to be as good as the manufacturer intended, then you should use a crimp tool that is recommended for the application.
Don't use any solder unless it is suggested in the fitting instructions - generally it will bind the cores together, preventing them from flexing correctly, which is not good for long term reliability. You may be able to make the crimp with pliers but it won't be as reliable as if you used the correct tool.
Post #630372 10th Jun 2017 3:11pm
👍🏻 You can solder too, but I wouldn't on small wires as you can get extreme heat build up very fast and scortch the insulation. I did mine with pliers and have never ever had an issue. You do need to be careful and precise though. I like Superseal connectors, very effective seal and easy to unplug. _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
Post #630373 10th Jun 2017 3:13pm
huffhuff
Cheers all. Will put it on the list for tomorrow Smile TD5 Defender 90
Discovery 3 HSE
Post #630383 10th Jun 2017 4:26pm
If you want a good durable connection you'll heed the advice of Thon.
Post #630444 10th Jun 2017 8:57pm
huffhuff
Ok. I'm in no rush. Who can find me the cheapest/best crimper that will do the job on eBay or Amazon Smile TD5 Defender 90
Discovery 3 HSE
Post #630447 10th Jun 2017 9:06pm
PaulMc
Pliers and soldering are not the way to go Shocked
There's a Durite ratchet crimping tool, designed for Superseal and Econoseal terminals, which crimps the conductor and wire seal in one operation -
It's available on ebay and from several auto electrical suppliers.
The cheapest I've found is from Autoelectricsupplies -
https://www.autoelectricsupplies.co.uk/product/922/category/87
You can make an acceptable crimp on Superseal and Econoseal terminals, with the cheapo crimping tool for non insulated terminals -
Here are a couple of Econoseal terminals that I crimped to 1.0mm² cable, using the above tools -
The terminal on the Black wire was done with the Durite ratchet crimper.
The terminal on the Blue wire was done with the cheapo crimper, using a combination of the smallest crimping die (1.25mm) for the conductor, and the cable stripper die (5.5mm) for the wire seal.
Edited to fix Photobucket's ransom demands Mad
. Paul.
Post #630479 10th Jun 2017 11:52pm
huffhuff
Thanks Paul, very thorough reply Smile
I'll look at getting a legit crimping tool. Any excuse to fill up the toolbox... TD5 Defender 90
Discovery 3 HSE
Post #630687 12th Jun 2017 9:32am
I recently swapped all of the lights on mine from the originals with bullet connectors to the more modern ones that use Econseal connectors. As I had a lot to do, I invested in a proper crimp tool like this:
It wasn't expensive from eBay but is sooo much better at making crimped joints. I'll never faff around with pliers again. Darren
Post #630691 12th Jun 2017 9:53am
