Home > Maintenance & Modifications > Connector to defend Puma
Morea
Hello. Does someone know where I can do myself with this connector? There is that of the light of fog a back. What I need is different with the cables to put in another equal button for the front fog. Thank you.
It is for this button
This one is the connector that I need.
 http://www.clublandrovertt.org/index.php?a...ype=avatar
Post #62926 9th Mar 2011 12:48pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
http://www.famousfour.co.uk/new_parts/part...tches.html Original Member Pie n Pea Club.
110 HCPU Tipper
Post #62929 9th Mar 2011 1:18pm
PaulMc
I read the OP's post as 'wants the connector' Confused
Anyway, the Black 5-way switch connector is available from Dingocroft, here -
http://shop.dingocroft.co.uk/acatalog/Elec...#aZZPLUG01
. Paul.
Post #62934 9th Mar 2011 2:41pm
110SEB
Post #62936 9th Mar 2011 2:48pm
willy eckerslike
My spanish is Censored  Original Member Pie n Pea Club.
110 HCPU Tipper
Post #62937 9th Mar 2011 2:58pm
PaulMc
Re: Connector to defend Puma
Re-reading your post, are you planning to use a Rear Fog Lamp Switch for Front Fog Lamps?
If so, I don't think that this switch will be suitable.
Regardless of it being an earth switching switch, it doesn't latch (stay 'on' when pressed).
The Rear Fog Lamps are actually switched on by an ECU, the Dash Switch only makes a 'momentary' earth path that signals the ECU to do the actual switching.
Land Rover supply a Front Fog/Auxiliary Lights Switch, Part No. YUG000540LNF
This switch also uses the Black connector and is also an earth switching switch, but it latches (stays 'on' when pressed in and switches 'off' (pops out) when pressed again)
Details on this switch and how to wire it are covered in this thread -
http://www.defender2.net/forum/topic552.html?start=18
I also noticed from your pictures, that your Rear Fog Lamp Switch appears to be missing it's illumination wire (Red/Orange wire to Pin 2) - it looks to have pulled out of the back of the connector.
. Paul.
Post #62938 9th Mar 2011 2:58pm
PaulMc
It's Spanish, is it Laughing
. Paul.
Post #62939 9th Mar 2011 3:00pm
Morea
Good, first of all pardon for my Englishman. What I am going to put is another independent button for the additional front beacons. Here in Spain encontre the switch, but he was not finding the connector. Now to seeing if someone of the links that me poneis me envia to Spain. Muchisimas thank you for everything. http://www.clublandrovertt.org/index.php?a...ype=avatar
Post #62964 9th Mar 2011 6:53pm
BigMike
Willy isnt an englshman, he s a yorkshireman, not the same thing Laughing
Post #62967 9th Mar 2011 6:57pm
Morea
Very Happy Is this better?
Well, first of all, sorry for my English. What I will take another separate button for additional headlights. Here in Spain I found the switch, but could not find the connector. Now to see if any of the links poneis me send me to Spain. Thank you so much for everything. http://www.clublandrovertt.org/index.php?a...ype=avatar
Post #62970 9th Mar 2011 7:07pm
bob neville
Your English is far better than my Spanish will ever be Thumbs Up
Bob
Post #62974 9th Mar 2011 7:43pm
Morea
Bob
thanks Very Happy http://www.clublandrovertt.org/index.php?a...ype=avatar
Post #62983 9th Mar 2011 8:18pm
JSG
If they don't, get one sent here and I will be happy to post it on to Spain for you Thumbs Up John
2011 Tdci 110 CSW XS
Post #63004 9th Mar 2011 9:44pm
Morea
Thank you. Already order them a mail and I wait for his answer. http://www.clublandrovertt.org/index.php?a...ype=avatar
Post #63017 9th Mar 2011 10:44pm
leeds
Morea, my Spanish is hopeless, much worse then your English.
However my partner Barbara is fluent in Spanish, (She can swear like a trooper in MexicanSpanish) If you need any help just pm me in Spanish and I can get Barbara to translate for you. She does struggle slightly on the more technical terms associated with vehicles but she will help if she can
Brendan
Post #63031 9th Mar 2011 11:31pm
