![]() | Home > Puma (Tdci) > Switch fascia |
| PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 511
That's because YUG000540LNF switches the earth from the accessory's relay and not the feed to it. If you use it to switch across pins 1 & 4, it will work as a simple On/Off switch but, you won't get either the green illumination or orange 'tell-tale' light to work, as they are LEDs and require the switch to be wired-up as designed. To help me understand how to wire up my auxiliary lamps, I sat down and drew a diagram showing how the switch is wired internally and then added a basic auxiliary light circuit to the diagram. The trigger is shown as coming from the High Beam warning lamp, this is for Driving Lamps. For Front Fog Lamps, this trigger would be taken from the Sidelights or Dipped Beam - depending on local lighting regulations. Click image to enlarge The proper Tyco/AMP Connector 347477-1 with 5 x crimp terminals is available from Dingocroft, their Pt No. ZZPLUG01 - http://shop.dingocroft.co.uk/acatalog/Elec...#aZZPLUG01
There's a lot more info here - http://www.landroveraddict.com/smf/index.p...546498#new Paul. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Last edited by PaulMc on 2nd Dec 2009 6:09pm. Edited 1 time in total |
| mse Member Since: 06 Apr 2008 Location: UK Posts: 5117
Or on my post here Its fitted and working... one comment - i havent my notes, but pins 1, 3 and 4 are linked...this is an earth contact switch Mike |
I never saw that thread You're correct, this switch is designed to switch a relay's coil to earth. Pins 3 & 4 (which are commoned) are connected to pin 1 when the switch is in the ON position. Here's a picture of the inside of the switch, which I've annotated to show how the contacts connect accross pins 1 & 4 when in the ON position - Click image to enlarge Looking at the circuit inside the switch - Click image to enlarge It would be easy to convert this switch to a conventional live switching ON/OFF switch by cutting the brass track between the two holes, as marked in red in this next picture - Click image to enlarge By cutting the track at this point, you separate pins 3 & 4 The revised circuit would be as follows - Pin 1 - Incoming Live from Main Beam/Dipped Beam/Side Lights (as applicable) Pin 2 - Live from Dash Illumination Pin 3 - Switch Earth (for indicator LEDs) Pin 4 - Switched Live output to Accessory Relay Pin 5 - Live in from Pin 4 (for Orange 'tell-tale' LED) You could link pins 4 & 5 inside the switch while you had it apart, by soldering a link across the brass tracks but I would just crimp an extra short length of cable into Pin 4 and loop it round into Pin 5 on the connector. You will still need to use an accessory relay with this switch modified in this way but, at least it will be wired in a conventional manner. Lastly, where did you source your connector from? I managed to get some connector shells from a company called Heart Electronics and the correct crimp terminals from RS Components. Paul. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
| Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2687
Paul, what do you need this connecter for? Will the switch not work by itself? |
It will work but you wont be easily able to connect anything to it! Mike
good thing I asked then. Why don't they just make the whole thing into one unit? |
Remember this is a standard switch to plug into a standard loom - common - what we are doing is a) not buying the loom b) modifying its purpose Mike
| p-j Member Since: 08 Aug 2010 Location: belgium Posts: 4 |
I want to place 2 switches for 4 spotlights on my roofrack and a worklight on the back
I already have my led worklight (8.5W) I have chosen the other lights the switches and the connectors have just been deliverd... So I'm ready to start BUT! please help me a litle: How thick do all those wires from the switch to the relay and to the earth have to be? (Those called UB, B and UY) For cable "R" I calculated: 4 times 55W + led worklight = 228.5W => 2.5mm² with fuse 20A Do I have to run an earth cable to the battery or is it safe to use a place under the hood? Finally: I want my worklight to go on and off by the switch and not to be triggered by the reverse. So I believe I just have to change the wire that is connected to "86" on the relay to be a +12V. So... can I just use the 12V that comes from my battery or do I have to use some other 12V source? Can't wait to start |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21042
The trigger is shown as coming from the High Beam warning lamp, this is for Driving Lamps. For Front Fog Lamps, this trigger would be taken from the Sidelights or Dipped Beam - depending on local lighting regulations. Click image to enlarge Yep, I did the same. What helped me was just to ALWAYS remember that between 85 on the relay and 86 is the coil (trigger) and 30 to 87 is battery positive to spot positive (switch) these will work the same in reverse also but who would want to i really don't know. But what you MUST not do is connecting up like 30 to 85 on my setup that would effectively put the battery positive to ground! Also make sure to remove the appropriate fuse and double check before connecting it all up. Unlike me and then wondered why the horn and main beam wasn't working i blew the fuse Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
Konabike's diagram and explanation is 'spot on' (no pun intended), all the information you need is contained within this thread, if you need any more just holler! Good luck! Treat every day as if it is your last....one day you will be right!! |
well, just to be sure
what do i have to connect to 86 if I want to use the swith as a regular on/off switch (I want to turn on my worklight manually, even when the engine is not running.) |
Any power source trigger...mine doesnt switch from the main beam (i didnt want to butcher that wiring or open that side of the dash. Mine has a trigger direct from the battery (all fused)...that is what you will need to do to the relay. Although i switch to earth not to power (a little easier wire wise) Mike |
| Myo Member Since: 13 May 2012 Location: Cape Town Posts: 30
So trying to avoid the extortionist cost of an aux 2 switch, is the heated seat switch circuit the same? Do I just need to change the front cap to use it as my light bar switch ( it cost £8-9 compared to the aux2 £50!!
The Puma heated seat switch YUF500150LNF will work, but it's a live-switching switch (the Defender Aux-2 switch YUG000540LNF is an earth-switching switch)
It just means that you have to wire your lamps to suit the switch - Pin 1 - Live in from fused supply Pin 2 - Dash illumination Pin 3 - Not used (but is internally connected to Pin 5 - Earth) Pin 4 - Switched live out to accessory Pin 5 - Earth e.g. - Click image to enlarge You can replace the heated seat switch's front with any other, including a modified blank (modified by drilling a 2.5mm hole in its front, to accomodate the tell-tale LED's lense) - Click image to enlarge Click image to enlarge . Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
| All times are GMT |
