Home > Technical > Red warning light below rev counter?
Page 2 of 2 <12
4wheeler
Australia 2013 Defender 110 Puma 2.2 SW Chawton White
As mentioned, I only suspect some form of interference as I know I have no issue with any door sensors. The suspected interference is intermittent in my case. I can drive the same section of road and not see the light activate for weeks then out of the blue in a round about the same spot it will illuminate. This scenario occurs at number of different places and that is why is suspect some form of interference. I could be wrong though. Being a Defender, it might just be messing with my head for fun!
It will be clocking up around 8000 km in the next 3 weeks so it will be interesting to see what happens in different areas.
Post #625566 20th May 2017 11:23am
4wheeler
So since my last post 3 weeks ago I have driven 8000 km up the east cost of Australia and back again. Apart from being a bit noisy, I can't believe how comfortable the box on wheels is to travel in over long distances. Some days were 800 km and you step out of the driver seat feeling fresh. As usual, people happily wandered over to chat to me about my Defender on the trip.
My alarm light flashed just outside a fuel station then after filling up the Defender did not start on the first key turn. It did start the second time. I noticed that when I fist turned the key the alarm light stayed on. The second time when the Defender started, the light extinguished as the key was turned.
Post #629820 8th Jun 2017 6:55am
Pat
Wales
I have also experienced the alarm indicator red flash and a little worried forum research has led me to this thread.
My occasional two or three red flashes happen randomly and without apparent cause - although a recent occurrence happened at speed bumps, so that one could have been door latch related.
Should I be worried? ............. this thread suggests not, but don't like things happening without cause.
Annoyingly my key fob rarely works first press, locking or unlocking, it's always been the same, even after a main dealer battery replacement. Is this common or do I have a duff fob? ........... or did I get a duff battery? Fob only seems to work close to the vehicle.
Post #638853 21st Jul 2017 7:39pm
keithwr
United Kingdom 2015 Defender 110 Puma 2.2 CSW Keswick Green
had similar problem red the tacho light came on and stayed on only went out with an engine restart changed the battery in the key problem resolved.
Post #723225 13th Aug 2018 3:04pm
JPE
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
I experienced a second or maybe two seconds of red flashing whilst driving along happily yesterday.
Having read this thread, I'm going to put it down to part of the wonderful mystery of defender ownership and just not worry about it... Smile
Post #749528 6th Jan 2019 11:06am
dorsetsmith
DanielSWE wrote:
Sorry, my bad.
The warning light does not flash, it's steady on.
driver door open or driver door switch fault
Post #749532 6th Jan 2019 11:24am
JPE
Thanks, I'll see if it happens again... & if so check the switch...
Post #749533 6th Jan 2019 11:30am
Wessex517
2014 Defender 110 Puma 2.2 USW Scotia Grey
I had a solid red light which was occasional and quite distracting at night. Changing the key fob battery fixed it.
Post #761201 28th Feb 2019 4:24pm
DSB
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Indus Silver
First port of call is the forum, all the info you need is here. My indicators stopped flashing, so fob battery needs changing, but in my Audi you can simply swap the battery in the house rather than sit in the drivers seat. Saved me some issues here
Post #767547 8th Apr 2019 8:21am
TSAF
Greece 2015 Defender 110 Puma 2.2 HT Venetian Red
do you have to seat in the drivers seat while changing the battery fob? Or I got this totally wrong?
Post #1047450 2nd Oct 2024 10:17am
Page 2 of 2 <12
