Home > Puma (Tdci) > Rusty bolts
Rallymental
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Santorini Black
Rusty bolts
Whilst giving the 110 it's annual wash at the weekend the wife noticed an odd thing. No, not me. She noticed that on the door hinges, one in every group of four has gone rusty, also on the front, one of the four bumper bolts has gone rusty as well, question is what do I do?
Do I get a stainless steel bolt kit and change them all or as its still under warranty get LR to change the rusty ones? The definition of insanity is doing the same thing over and over again but expecting different results.
Solihull, 1948 - "If we paint the chassis, it will last for years"
Solihull, 2015 - "If we paint the chassis.............................
Post #629392 6th Jun 2017 9:36am
Balvaig
Not unusual, some of mine went rusty. Also quite random.
Depends on wether you want to argue with the dealer as to warranty covering rusty bolts.
I just bought original replacement bolts and did it myself. Not a big job. Now liberally coated with ACF50 on a regular basis.
Post #629403 6th Jun 2017 10:00am
Stacey007
Hello
Changed most of mines the other day Smile
http://www.defender2.net/forum/topic54898.html
Used copper grease to re tighten, just need to take the rear trim off to do 2 more and they are all done Smile
The dealer will just replace with the same bolts which will do it again I guess?
Easy and cheap 'mod'
Post #629416 6th Jun 2017 11:25am
Get them replaced under warranty, remove right away and sell as new take off Genuine.
Then fit SS kit. Wink ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #629418 6th Jun 2017 11:27am
Lightningtweeds
Scotland 2008 Defender 90 Puma 2.4 CSW Stornoway Grey
I once queried why a brand new Defender had red rusty grille screws and i was told farmers didn't want to pay for protected items.
Post #629459 6th Jun 2017 1:21pm
andydef90
United Kingdom 2014 Defender 90 Puma 2.2 HT Corris Grey
i had the same thing on mine i removed them cleaned them up repainted them and they have been fine . i do now invest in acf50 as already mentioned its expensive but considering the cost of a defender its well worth it Smile
Post #629461 6th Jun 2017 1:32pm
Rallymental
Thanks all! Thumbs Up The definition of insanity is doing the same thing over and over again but expecting different results.
Post #629475 6th Jun 2017 2:10pm
Crofter
United Kingdom 2009 Defender 110 Puma 2.4 USW Baltic Blue
I replaced the front bumper bolts with stainless steel bolts, but for all it would cost I think these should have been fitted at the factory. My door hinge bolts have a few rusty bolts. These have not been replaced but again should have been stainless steel.
Sorry just a whinge.
Post #631294 14th Jun 2017 12:34pm
ericvv
This thread may be worth a read.
http://www.defender2.net/forum/topic38216....eel+weicon
And then make up your own mind what is best.
I would buy a pot of Weicon, buy replacements for the rusty bolts, dip the new and screw in. Then one by one take all others out too, dip in Weicon, put back in. Basic preventive maintenance you know.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #631343 14th Jun 2017 4:19pm
Crofter
Interesting thread. I think I understand what is being said I need to think about this, maybe try it.
Post #631693 15th Jun 2017 9:07pm
BarryT
Wales 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
Had the same problem with 6 hinge bolts rusting, took for it's 2 yr service last Wed and only mentioned it to the service lads at Conwy Land Rover and when I picked it up they had replaced all 16 bolts on the side doors, So my advice would be to mention it to your dealer and get them done under warranty.
BarryT
Post #631857 16th Jun 2017 7:05pm
zsd-puma
Get them done under warranty, then replace the door ones with stainless next time around.
If you've ever any intention of fitting a winch, HD bumper or a towball on the front bumper don't bother with stainless bumper bolts as they're not as strong. If you buy the britpart bumper fitting kit it comes with slightly longer high tensile bolts with plastic caps to cover the heads. Wink
Post #631879 16th Jun 2017 9:38pm
Crofter
My Defender is a 2009 so its long out of warranty. But I do need to replace the rusty ones.
Post #631931 17th Jun 2017 1:19pm
