Home > Maintenance & Modifications > Jate rings as rear recovery points on a 90
Page 2 of 2 <12
No reason you shouldn't use a four-bolt 5-tonne jaw and pin coupling on the crossmember (use the reinforcing plate) instead of a NATO pintle. A jaw will be massively cheaper if buying new, and is simpler and lighter.
Post #627716 30th May 2017 10:24am
Devon-Rover
Exactly what blackwolf said above.
If you are after just purely a recover point then a Jaw using a pin will be in my opinion be a safer and stronger. IMHO the NATO will do as a recovery device but it is still primary a towing device and i'm not a fan of exerting that type of force through it.
Something like this >> http://dixon-bate.co.uk/products/gb/univer...coup-.html
Means a captive rope holder and the force of the recovery is being exerted in the same direction as it has been designed to work with. If we use a historical view the 3.5ton Dixon bate jaw http://dixon-bate.co.uk/products/gb/jaws/1...coup-.html is what was used for the camel trophy as a recovery point.
Post #627756 30th May 2017 2:28pm
roel
You mentione light off-roading. But off-roading light doesn't mean your recovery will be light.
Ok I am normally not somebody who goes for light off-roading but still I happen to get suddenly unexpected very stuck.
Like here, this looked like a short easy climb. (I am on 35" Simexes) I just suddely sunk in.
 Roel
2003 90 Td5 (2009-now)
Post #627775 30th May 2017 4:55pm
Thon
thor44 wrote:
@Thon: From GB to the Alps twice in three months in a Defender....there must be nothing you fear. Very Happy Just an advice: In July there will be quite a few tourists up there. If you want to save some money, drive up to the "Drei Zinnen" as we call them from the northern side after 3 in the afternoon. The majority of people will then be on their way home, it won't be as warm plus if you stay long enough you will see one of the most stunning sunsets in the Dolomites. Just don't forget to bring a headlight then Very Happy
I'm being slightly disingenuous - I'm not driving back there from the UK - I live in Veneto until the autumn so it's only 2 hours away. Unfortunately arriving at 3 won't work as we're intending to walk the 10km route around the Peaks so we'll need to start early, particularly bearing in mind my level of fitness Smile hopefully we'll stay long enough for the sunset anyway but we'll be carrying 2 x 9 month old girls with us so it will be up to them mostly. It'll still be wonderful whatever happens!
Post #627833 30th May 2017 8:14pm
thor44
2014 Defender 90 Puma 2.2 SW Indus Silver
Thank you all. So I'll be going for a jaw. Does anybody have the part number for the reinforcing plate? (if there is any - is KNK100090K still available from Land Rover?)
@roel: That's exactly how stuck I wish I'll never get. Holy crap. Very Happy But I guess one has to be prepared for anything, right?
@Thon: Haha, that makes sense. I'm glad to hear that as I would have been really devastated to hear that some people are driving twice from the UK to the Alps and back in three months (with two 9 month old girls) and I am afraid of a 1.600km drive to Denmark for months before even starting. Very Happy
Nevertheless have a great time. I'm sure it will be wonderful. All the best to you, your wife and the girls. . _____
.|_____\___
[|_/-\__/-\_|}
...(O)....(O)........ MY14 2.2 Defender 90 SW
Post #627893 31st May 2017 8:15am
Latest plate is KNK500030 and if you type "Defender NATO plate" or that part number into eBay you'll find many at prices from £5.69 inc p&p upwards, all NOS.
Post #627895 31st May 2017 8:55am
thor44
Wow, that's much cheaper than expected. Thanks a lot blackwolf. . _____
.|_____\___
[|_/-\__/-\_|}
Post #627916 31st May 2017 10:30am
Yes, it's a nice surprise (and all too rare) that a Genuine Part is far cheaper than you expect!
Almost makes you want to buy several of them 'just in case'! Very Happy
Post #627930 31st May 2017 11:24am
thor44
Haha, exactly my thoughts Very Happy Very Happy Very Happy . _____
.|_____\___
[|_/-\__/-\_|}
Post #627946 31st May 2017 12:34pm
thor44
Update: Instead of buying something to bolt on to the rear crossmember I decided to design something myself and a friend of mine welded it together:
I decided to use as many bolts as possible and included the L-profile of the previous tow hitch as well. I hope this plate is up to all recoveries I'll have to do and spreads the forces sufficiently.
For the front I ordered some JATE rings from paddocks and obviously they don't fit as I have mounted the original tubular steering guard. Can I remove 2mm on the inside of each side of the JATE ring without weakening the rings too much? The wider JATE rings of most shops seem to have been filed down anyways...
Example from http://www.landroverstuff.com/jaterings.htm :
 . _____
.|_____\___
[|_/-\__/-\_|}
Post #631527 15th Jun 2017 10:58am
Def90
United Kingdom 2015 Defender 90 Puma 2.2 SW Corris Grey
You can get them to fit the rear of a late 90 but it's a little tight between the fuel tank and the outer edge of the JAT ring, you can't see from the photos but I only have 2-3mm clearance.
Also it's a bit of work fitting a threaded insert into one side of the JAT ring so you don't have a nut or bolt head protruding as it would foul the fuel tank.
Front ones look OK
Post #650878 17th Sep 2017 9:48pm
thor44
Hi Def90, thanks for the photos! Thumbs Up
Did you have to drop the tank or anything like that to install them? I presume yours had the shipping/towing eyes as well. Did you have to grind those off to remove them? . _____
.|_____\___
[|_/-\__/-\_|}
Post #650920 18th Sep 2017 7:25am
Def90
Hi Thor44
The factory shipping/towing eyes just unbolt but you will need to drop the fuel tank to remove the original bolts that retain them, my tank had to come out to fix the tank breather pipe!
When I re installed the fuel tank I also fitted solid rubber pads either side of the fuel tank between the tank and the chassis rails as a precaution to stop the tank from moving from side to side and hitting the JAT ring as they are very close.
On the pictures of the military defenders fitted with rear JAT rings that I have seen,it appears they re use the original factory shipping/towing eyes but swing them around and use them as a spacer for the JAT ring.
I decided to make up some spacers as these shipping/towing eyes are 1.5mm too thin and you will crush the JAT ring when you tighten them up.
These are not fitted as recovery points but are just for lashing down as per the original factory shipping/towing eyes.
Post #650946 18th Sep 2017 10:18am
thor44
Thanks a lot for the update. If I get around to drop the tank sometime in the future, that'll be the thing to do. Thumbs Up . _____
.|_____\___
[|_/-\__/-\_|}
Post #650955 18th Sep 2017 11:23am
Page 2 of 2 <12
