Home > Maintenance & Modifications > Small crack in wheel arch advice.
Hunky Gibbon01
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Zermatt Silver
Hi all. Decided to put a crack in wheel arch driver side front while green laning. As pics show. Tiny as it is, you all reckon to...
A) leave it, I not too bothered how it looks, as it scratched anyways. But will crack grow?
B) use some sort of clever glue (please specify clever glue) to join?
C) proper repair myself or get a body paint place?
D) replace with ultimate massive mud type or equivalent arches?
E) buy new ones and paint?
F) suggest something magical?
Not bothered how it looks, and cheapest option and or most effective option shall be considered.
Post #627232 27th May 2017 6:11pm
Plastic weld from behind.
I have an arch with a crack in it I've taken off.
When I eventually get time I'll repair and re prime to sell.
Plastic zip ties are suitable to plastic weld.
However, make sure you are in good ventilation and do not breathe the fumes.
Thumbs Up _\Hennessey|Venom| F5/___
___\â­ï¸Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_
Post #627238 27th May 2017 6:34pm
zsd-puma
If you don't care what it looks like there are two options.
Take a small drill bit, slightly wider than the crack and drill a hole at the end of the crack - this will stop the crack from growing any further - unless you smash the vehicle into something hard again obviously.
another option is to drill holes either side of the crack and stitch it with cable ties - it will look ugly, but will be as strong as the original material.
Post #627242 27th May 2017 6:43pm
Bobtailkev
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
I had the same thing happen. I fixed a fine piece of metal mesh with black CT1 adhesive and it's worked a treat. If you would like a piece of mesh, private message me and I'll send you some.
Post #627244 27th May 2017 7:09pm
Lightningtweeds
Scotland 2008 Defender 90 Puma 2.4 CSW Stornoway Grey
There are some on Ebay?
Post #627299 28th May 2017 8:13am
Hunky Gibbon01
I did have a look on eBay. Single ones unpainted new £50-ish and used scratched one £36. So i did consider to buy used one and paint. But buying all the stuff expensive.
Thank though Thumbs Up
Post #627310 28th May 2017 9:36am
Thornton breakers, then paint.
Shouldn't need repainting just lightly flat the original paint, _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
Post #627331 28th May 2017 11:43am
foxyred
England 1994 Defender 90 200 Tdi HT Montalcino Red
Thorntons supply of Defenders seams to be drying up on their website they have not had a defender in 2017
Post #627335 28th May 2017 12:25pm
I have one on the side myself with a crack much less significant than the OP's.
But it isn't in flawless condition, have very got around to repairing. Maybe I'll give it a go soon. _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
Post #627340 28th May 2017 1:27pm
