![]() | Home > Maintenance & Modifications > Small crack in wheel arch advice. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20978 ![]() ![]() |
Plastic weld from behind.
I have an arch with a crack in it I've taken off. When I eventually get time I'll repair and re prime to sell. Plastic zip ties are suitable to plastic weld. However, make sure you are in good ventilation and do not breathe the fumes. ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
If you don't care what it looks like there are two options.
Take a small drill bit, slightly wider than the crack and drill a hole at the end of the crack - this will stop the crack from growing any further - unless you smash the vehicle into something hard again obviously. another option is to drill holes either side of the crack and stitch it with cable ties - it will look ugly, but will be as strong as the original material. |
Bobtailkev Member Since: 17 Mar 2016 Location: Suffolk Posts: 111 ![]() ![]() ![]() |
I had the same thing happen. I fixed a fine piece of metal mesh with black CT1 adhesive and it's worked a treat. If you would like a piece of mesh, private message me and I'll send you some.
Lightningtweeds Member Since: 16 May 2017 Location: Fintry Posts: 461 ![]() ![]() ![]() |
There are some on Ebay?
Hunky Gibbon01 Member Since: 20 Mar 2017 Location: Dorset Posts: 90 ![]() ![]() ![]() |
I did have a look on eBay. Single ones unpainted new £50-ish and used scratched one £36. So i did consider to buy used one and paint. But buying all the stuff expensive.
Thank though ![]() |
Thornton breakers, then paint.
Shouldn't need repainting just lightly flat the original paint, ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
foxyred Member Since: 16 Jul 2016 Location: Nottingham Posts: 227 ![]() ![]() ![]() |
Thorntons supply of Defenders seams to be drying up on their website they have not had a defender in 2017
I have one on the side myself with a crack much less significant than the OP's.
But it isn't in flawless condition, have very got around to repairing. Maybe I'll give it a go soon. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
