![]() | Home > Td5 > Defender TD5 hub nut torque |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1789 ![]() ![]() ![]() |
Has the spacer gone missing? There should be a spacer between the 2 bearings. This takes the torque of the nut, rather than the bearing.
If the spacer is missing, the wrong size, or non genuine bearings have been used with differences in tolerances, that could cause the issue you're having. The single nut you have, is it a stake nut, with the collar to hammer flat to retain it? |
Charlie_79 Member Since: 12 May 2017 Location: england Posts: 5 ![]() |
thanks for the reply, the spacer has been put in there, yes its a stake nut with the collar that you push down,
Are you using timken bearings?
Most of the time you can reuse the spacer as the tolerances are close enough, the different size spacers are mostly to take up variances in the original hub casting. You can either try and source the correct hub spacer, or probably much easier to just get the parts to convert to the 2 nut setup! |
I'd also take the time to check the other three with a view to replacing hub nuts there. If someone has left one corner like this then the others may be the same!
![]() Click image to enlarge item 30 shod read Move HUB assembly in and out noting dial gage reading ![]() Click image to enlarge Last edited by dorsetsmith on 22nd May 2017 9:54am. Edited 1 time in total |
i think your right, i may just switch to the old style where i take the spacer in the middle out and just put the bearing back in and use 2 locking nuts. seems like an a lot easier way to do it.
also i am using britpart bearings |
have used LR timken bearings and timken bearings from them with stake nut and have not problems 70.000 mile and still going strong
used none branded bearings and the only way set then up by using 2 nut setup as the tolerances tuned out to be out ![]() |
If you have to replace the wheel-bearings, the hub, or the stub axle then it is generally easier to convert to the earlier, two-nut-and-no-spacer, arrangement. In your case it is clear that the spacer currently fitted is unsuitable for the bearings and you need a thicker spacer.
If you have replaced the bearings and used OEM bearings (Timken), then there is a reasonable probability that the original spacer will correct, since quality bearings are manufactured to extremely tight tolerance. If you use bearing from a different manufacturer, especially 'cheap' bearings from the far East, then it is most unlikely that the spacer will be correct and indeed you may find that none of the available spacers are correct. In this case then your only option is the two-nut-no-spacer set-up. The good thing is that there are really no downsides to converting to the earlier set-up. |
MalteseRover Member Since: 02 Jul 2013 Location: Gozo Posts: 137 ![]() ![]() |
Hello,
Dumb question but do you need to replace the complete stub assembly in order to revert to old two nut assembly or it is just a matter of sourcing two nuts and tab washer? Thanks. Joseph PS: Will a loose wheel bearing likely cause death wobble too? (the play is minimal but can feel it) |
bodstruck Member Since: 09 May 2020 Location: Wiltshire Posts: 1003 ![]() ![]() |
Just need 2 nuts and a lock washer.
