Home > Td5 > Defender TD5 hub nut torque
Charlie_79
hi everyone, yesterday i replaced my drivers side swivel ball joint, cv, joint, stub axle, and wheel bearings, when taking it all apart i noticed that the hub nut (i have the new design with only 1 nut not 2) was only just tighter than finger tight at the time i just carried on going with what i had to do but then once i had fitted all the new parts and came to putting a new hub nut back on i could only torque it up to about 60nm without it tightening the wheel bearing far too much and making it not move freely, i looked at my manual and it says it should be something like 240nm i think !, does anyone know whats going wrong and why i can't tighten it up properly ?
any advice would be very helpful
charlie
Post #625964 22nd May 2017 8:03am
miker
Has the spacer gone missing? There should be a spacer between the 2 bearings. This takes the torque of the nut, rather than the bearing.
If the spacer is missing, the wrong size, or non genuine bearings have been used with differences in tolerances, that could cause the issue you're having.
The single nut you have, is it a stake nut, with the collar to hammer flat to retain it?
Post #625968 22nd May 2017 8:43am
Charlie_79
thanks for the reply, the spacer has been put in there, yes its a stake nut with the collar that you push down,
Post #625969 22nd May 2017 8:49am
miker
Are you using timken bearings?
Most of the time you can reuse the spacer as the tolerances are close enough, the different size spacers are mostly to take up variances in the original hub casting.
You can either try and source the correct hub spacer, or probably much easier to just get the parts to convert to the 2 nut setup!
Post #625970 22nd May 2017 8:51am
miker
I'd also take the time to check the other three with a view to replacing hub nuts there. If someone has left one corner like this then the others may be the same!
Post #625971 22nd May 2017 8:53am
dorsetsmith
item 30 shod read Move HUB assembly in and out noting dial gage reading
Post #625972 22nd May 2017 9:12am
Charlie_79
i think your right, i may just switch to the old style where i take the spacer in the middle out and just put the bearing back in and use 2 locking nuts. seems like an a lot easier way to do it.
also i am using britpart bearings
Post #625974 22nd May 2017 9:30am
dorsetsmith
have used LR timken bearings and timken bearings from them with stake nut and have not problems 70.000 mile and still going strong
used none branded bearings and the only way set then up by using 2 nut setup as the tolerances tuned out to be out Exclamation but this is on trailer LR hubs only
Post #625979 22nd May 2017 9:47am
If you have to replace the wheel-bearings, the hub, or the stub axle then it is generally easier to convert to the earlier, two-nut-and-no-spacer, arrangement. In your case it is clear that the spacer currently fitted is unsuitable for the bearings and you need a thicker spacer.
If you have replaced the bearings and used OEM bearings (Timken), then there is a reasonable probability that the original spacer will correct, since quality bearings are manufactured to extremely tight tolerance. If you use bearing from a different manufacturer, especially 'cheap' bearings from the far East, then it is most unlikely that the spacer will be correct and indeed you may find that none of the available spacers are correct. In this case then your only option is the two-nut-no-spacer set-up.
The good thing is that there are really no downsides to converting to the earlier set-up.
Post #625981 22nd May 2017 9:55am
MalteseRover
Malta
Hello,
Dumb question but do you need to replace the complete stub assembly in order to revert to old two nut assembly or it is just a matter of sourcing two nuts and tab washer?
Thanks.
Joseph
PS: Will a loose wheel bearing likely cause death wobble too? (the play is minimal but can feel it)
Post #858127 25th Sep 2020 6:51pm
bodstruck
Just need 2 nuts and a lock washer.
Post #858134 25th Sep 2020 7:34pm
