Home > Maintenance & Modifications > LEDs all round ?
corgi1
England 2009 Defender 90 Puma 2.4 XS CSW Stornoway Grey
LEDs all round ?
afternoon ladies and gents, going to get either wipac or rdx lights and fit them this week end, are they plug and play?, ive just seen something on youtube that shows making new spade connectors, and drilling the new holes in the bodywork as the screw holes are in a different place ?
cheers
Pete
Post #625356 19th May 2017 12:26pm
huffhuff
United Kingdom 2001 Defender 90 Td5 HT Java Black
I have a 2001 TD5 and went with the WIPAC set. My existing reverse and fog lights are the square/rectangle type (which I actually prefer). Included in the kit are round NAS style on plinths. So, there will be some fettling when I get around to it...the reverese and fog are currently sat under my desk. All the others were simple plug and go. TD5 Defender 90
Discovery 3 HSE
Post #625367 19th May 2017 1:00pm
V8GPC
300TDI onwards are plug and play; and use the existing screw holes in to plastic fixings.
Older land rovers will require drilling holes (very stright forward for self tappers); and ideally adding new style connectors to the loom, or chopping off and using new bullet crimps all round.
Crimps are not ideal where you expect to get water; but are easily accessible and can be replaced if you get any issues later on. Eitherway they are an improvement of the original old style lamps and bulbs
Post #625394 19th May 2017 3:06pm
I have a RDX and their Relay. Faultless, no issues.
On a Puma, they have Econoseal connectors which are plug and play.
No wiring involved.
However, you may need to crimp the connectors which isn't difficult and identify the positive and negative power feeds.
If you have no multimeter to do this, I'm sure embers here can tell you the wire colours instead.
You won't regret it. Thumbs Up _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #625412 19th May 2017 4:09pm
Older Land Rovers require larger holes cut into the bodywork to clear the later light bodies and the later lights will require Econseal connectors adding to the loom as the connectors on the lights are a moulded part of the body.
I've recently converted all of the lights on my 200tdi to the later type. Darren
Post #625420 19th May 2017 4:33pm
zsd-puma
Not with the RDX ones, as they have small tails on the back, you can just cut off the econoseal connector. Although it is a better connector so would make sense to fit one to the loom.
The backs of the RDX lamps are flat so you wouldn't need to enlarge the hole either.
If your current lamp lenses are retained by screws then you wont need to drill screw holes for the RDX lamps. If your current lamps are the old ones where the lens pushes into a rubber retainer and has a chrome locking ring, then you'll need to drill holes.
The wipac ones may be diferent, i've only used the RDX ones.
Post #625445 19th May 2017 6:48pm
tolley
United Kingdom 2006 Defender 90 Td5 CSW Oslo Blue
anyone recommend where to get the kits from ?
Post #625461 19th May 2017 7:30pm
http://www.ebay.co.uk/sch/i.html?_odkw=rdx...p;_sacat=0 _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #625463 19th May 2017 7:35pm
zsd-puma
Post #625475 19th May 2017 8:22pm
Ah, fair enough. I didn't realise that they were so different from regular ones. Darren
Post #625490 19th May 2017 10:23pm
Stacey007
I took ages deciding what to go for and colours...
Went for wipac fronts and NAS style wipac rears on aluminum plinths.
Much brighter and safer : plug and play (with the relay also)
still need to fit the alloy plinth to the fog and reverse light
I like them Thumbs Up
Post #625495 19th May 2017 10:38pm
