![]() | Home > Maintenance & Modifications > LEDs all round ? |
huffhuff Member Since: 05 May 2016 Location: Home Counties Posts: 379 ![]() ![]() ![]() |
I have a 2001 TD5 and went with the WIPAC set. My existing reverse and fog lights are the square/rectangle type (which I actually prefer). Included in the kit are round NAS style on plinths. So, there will be some fettling when I get around to it...the reverese and fog are currently sat under my desk. All the others were simple plug and go. TD5 Defender 90
Discovery 3 HSE |
V8GPC Member Since: 18 Jul 2016 Location: Manchester Posts: 289 ![]() ![]() |
300TDI onwards are plug and play; and use the existing screw holes in to plastic fixings.
Older land rovers will require drilling holes (very stright forward for self tappers); and ideally adding new style connectors to the loom, or chopping off and using new bullet crimps all round. Crimps are not ideal where you expect to get water; but are easily accessible and can be replaced if you get any issues later on. Eitherway they are an improvement of the original old style lamps and bulbs |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20999 ![]() ![]() |
I have a RDX and their Relay. Faultless, no issues.
On a Puma, they have Econoseal connectors which are plug and play. No wiring involved. However, you may need to crimp the connectors which isn't difficult and identify the positive and negative power feeds. If you have no multimeter to do this, I'm sure embers here can tell you the wire colours instead. You won't regret it. ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Older Land Rovers require larger holes cut into the bodywork to clear the later light bodies and the later lights will require Econseal connectors adding to the loom as the connectors on the lights are a moulded part of the body. ![]() Click image to enlarge I've recently converted all of the lights on my 200tdi to the later type. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
Not with the RDX ones, as they have small tails on the back, you can just cut off the econoseal connector. Although it is a better connector so would make sense to fit one to the loom. The backs of the RDX lamps are flat so you wouldn't need to enlarge the hole either. If your current lamp lenses are retained by screws then you wont need to drill screw holes for the RDX lamps. If your current lamps are the old ones where the lens pushes into a rubber retainer and has a chrome locking ring, then you'll need to drill holes. The wipac ones may be diferent, i've only used the RDX ones. |
tolley Member Since: 07 Nov 2011 Location: gloucester Posts: 1125 ![]() ![]() ![]() |
anyone recommend where to get the kits from ?
http://www.ebay.co.uk/sch/i.html?_odkw=rdx...p;_sacat=0 ____\We|Will|Win/___
Ah, fair enough. I didn't realise that they were so different from regular ones. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3882 ![]() ![]() |
I took ages deciding what to go for and colours...
Went for wipac fronts and NAS style wipac rears on aluminum plinths. Much brighter and safer : plug and play (with the relay also) ![]() Click image to enlarge ![]() Click image to enlarge still need to fit the alloy plinth to the fog and reverse light I like them ![]() |
