![]() | Home > Td5 > Replacing fuel pump on Td5 90 |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1673 ![]() ![]() |
replace the sealing ring on the pump
be gentle with the pipe clips when you take them off,you can buy a tool to help remove them. clean and vac any debris off before you start removing the old one the pump securing ring i often corroded,there is a plastic and metal one available fuel filter makes sense at the same time if you dont want to drop the tank you can use one of these to cut a hole on the flor looks neat and is easy to remove in future if you fit it with rivnuts http://www.ebay.co.uk/itm/like/17267600200...amp;crdt=0 and finally make sure you get the correct pump as the depth of the pump varies with model |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 ![]() ![]() ![]() |
This might help I did mine a few years ago and here's the how to thread
http://www.defender2.net/forum/post298155.html#298155 2008 110 2.4 XS Utility (Hagrid) 2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 689 ![]() ![]() ![]() |
Clean and vacuum any debris on the top of tank - definitely yes. And for the rest apply a bit of WD40 and clean with a rag. WD40 (or another thin oil) will stick the rest debris and lower their chance to fall down into the tank. "Drobek" = The Small One - Discovery 2, "BlufĂnek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
