Home > In Car Electronics > Unused lcd screen 2008 defender?
smudger100
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Hi - Looks like the blank screen underneath fuel and temp gauge is for a trip computer ? Can one be fitted on 2008 defender?
The pic is one i just noticed on the net which got me thinking.....
Post #624257 15th May 2017 10:45am
Stacey007
Hello
People have fitted the ultra gauge in this gap, tricky but can be done.
I just use it here Smile
works very well but the built in method look factory Smile
Post #624261 15th May 2017 10:59am
VVS210
Sorry if this is OT but what is the steering wheel you have Stacey007? - I'm not familiar with Pumas, is this standard and if so how many splines on the column?? I'm looking to replace the worn one on my DCPU and like the look of this one.
Post #624263 15th May 2017 11:06am
smudger100
Ok - Thanks for info 007. Where does the Ultra plug into?
Post #624264 15th May 2017 11:06am
smudger100
Ditto VVS210 on the steering wheel - nice!
Post #624265 15th May 2017 11:07am
ibexman
Looks like a startech wheel
Post #624268 15th May 2017 11:12am
X4SKP
Post #624271 15th May 2017 11:15am
VVS210
Thanks - it looks great but not £450 great... Thud
Think I'll stick to the standard factory leather version then I won't be so worried about getting mud and claret on it...
Post #624281 15th May 2017 12:16pm
Roy5695
The ultraguage unit plugs into the port where the dealers plug into to read fault codes, cable is easily fed behind the dash to the plugs location. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #624307 15th May 2017 1:33pm
zsd-puma
Re: Unused lcd screen 2008 defender?
[/img]
In a nut shell no you cant. The picture shows a Freelander 2 (high line) or Discovery 3 dash, which LR obviously recycled in a cut down form for the 2007 on Defender. The Freelander 2 and Discovery cluster will fit in the Defender dash but it wont work.
As others have pointed out, there are after market displays than can be stuck in the same location.
Post #624327 15th May 2017 2:33pm
Stacey007
Hello
Yes its a Startech wheel around £450 new but I was lucky and found a member selling one half price Smile
I heard a Metro wheel is very similar in size. Smile
The gauge plugs into the OBDII port just under your right knee. It can be used to reset codes, fault find, or as I use it for MPH, Rev, Temperature etc. As mentioned cable hidden from view Smile
Thanks
Post #624330 15th May 2017 2:38pm
