Home > Technical > Oil drip on handbrake drum
Leviathan
Ive noticed a slight oil drip on the handbrake drum and staining around the end of the transfer box. The handbrake works fine.
I have read there was a recall on this but wondered what the job entails and what parts are required. Id rather do this myself tbf.
Ta
Nick
Post #622287 7th May 2017 12:48am
dorsetsmith
The job entails
STC3433 Kit-flange,Rear
and one of these in stead as the kit seal will be unbranded unless you go for (LR)
rear prop removed 9/16 AF ring spanner and or http://www.paddockspares.com/da1119-propsh...50gbp.html
back off brake shoes 17mm open ended spanner
remove brake drum may be healed in place with 8mm countersink screw
drain transfer box oil
remover 20mm nut from flange and remover rear flange
remover old oil seal
refit new oil seal down to its home on the shoulder (also run small amount of grease in the seal before fitting it)
having removed [ 3/8UNF x 1 3/4 ]bolts from the old flange and fitted them to the new one with new mud shield or use new FRC3602 [ 3/8UNF x 1 3/4 ]bolts
fit new drive flange felt washer, plane washer and nut tighten up nut (148Nm or 109 ft-lb ) 2.4 defender > 07
refill transfer box oil EP 80/90
clean brake shoes and assemble with brake cleaning or ( replace brake shoes )
replace brake drum and adjust shoes also then all is finished teat handbrake
refit prop shaft new nuts NZ606041L [ UNF - 3/8 nylocks ] X 8
make shore transfer box breve pipe is not blocked
have fun
Next
Post #622303 7th May 2017 6:14am
Leviathan
Thats exactly what I was after DS.
You're a star.
Nick
Post #622336 7th May 2017 9:53am
Peter Td4
Belgium 2008 Defender 110 Puma 2.4 HCPU Santorini Black
Excellent info, thanks Thumbs Up
I also have this planned soon. Peter,
Defender 110 StaWa - Td5
Defender 110 HCPU - Puma
Defender 90 Soft Top - Td5
Post #622347 7th May 2017 10:37am
dorsetsmith
Post #622596 8th May 2017 9:09am
Leviathan
Just had a go at this and on removal of the handbrake drum found its bone dry inside.
Assuming the seal kit mentioned here isnt leaking I replaced the drum and reconnected the prop.
So thing is, should I have replaced the seal or is it leaking from a different area?
BTW if you are going to do this make sure you have some new 9/16 nyloc nuts ready because the old ones are a b*gg*r to get off and will be rounded.
Post #627346 28th May 2017 3:05pm
They're 3/8" UNF Nylocs.
Post #627439 28th May 2017 9:47pm
Leviathan
Sorry yes of course 3/8" UNF. I used a 9/16 spanner and that was in my head Rolling Eyes
Post #627455 28th May 2017 10:09pm
Bushpig
Wales 2012 Defender 110 Puma 2.2 SW Alpine White
Perhaps look at the intermediate shaft seal? It is on the front of the T/box.
I too had a leaking T/box that was dripping onto the handbrake drum, but not inside.
It was a box out job and ended up replacing the intermediate shaft also... Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so.
Douglas Adams
2012 2.2 Puma
Post #627489 29th May 2017 5:58am
Leviathan
I'll wait until something else goes in that area then. Shocked
Its not that bad atm.
Post #627522 29th May 2017 12:01pm
