Home > Maintenance & Modifications > Nakatanenga rear door gas strut V2
Page 2 of 2 <12
Andrew*Debbie
Just ordered a V2 kit for our 110.
Can anyone recommend a suitable rivet gun?
Don't want to buy a random tool off of Amazon and have it break.
Post #620113 28th Apr 2017 11:01am
L90Andy
United Kingdom 1997 Defender 90 300 Tdi ST Nato Green
I've got the V2 kit, you won't be disappointed.
I didn't have a mother of all rivet guns either, so fitted it with decent self tappers and loctite.
Working well so far with no issues. Also has the benefit of keeping the drilled holes smaller, thereby giving the option of enlarging at a later date if needed. Instagram: L90andy
My 1984 Ninety: http://www.defender2.net/forum/topic56071.html - SOLD!
My 2015 Defender: http://www.defender2.net/forum/topic39625.html - SOLD!
Post #620117 28th Apr 2017 11:12am
Andrew*Debbie
MOARG. Now I really want one Rolling with laughter
Self tapping screws are a good idea. will consider that instead of rivets
Post #620124 28th Apr 2017 11:28am
Likely to work loose imo unless you use loctite or similar at least. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #620129 28th Apr 2017 11:47am
Andrew*Debbie
The Nakaanenga web site says all fittings are stainless steel. I'm guessing that includes the rivets. EDIT: I just asked Nakatanega.
So MOARG or locktite ??
https://www.nakatanenga.de/en/optional-equ...2002?c=361
Post #620145 28th Apr 2017 12:57pm
Stacey007
I have this one bought off a forum member?
No idea what MK it is but literally fitted in ten mins
Works a treat
Thumbs Up
Post #620152 28th Apr 2017 2:02pm
leeds
The brackets and lock nuts are stainless.
The body of the rivet will be aluminium. You would need to be rather strong to deform a stainless steel rivet. I do not know what material the rivet shaft is made off
Brendan
Post #620156 28th Apr 2017 2:12pm
Andrew*Debbie
Oh good. Then I don't need the MOARG.
SS pop rivets do exist. They need a hefty rivet gun.
For example:
http://uk.rs-online.com/web/p/rivets/5124094/
Post #620168 28th Apr 2017 3:30pm
leeds
Interesting. I know the rivets are harder then standard pop rivets to fix. Never thought that the rivet body would be stainless. Embarassed
Will be interesting to hear what Mr Nakatanenga says the rivet body material is.
You live and learn!
Brendan
Post #620170 28th Apr 2017 3:58pm
Andrew*Debbie
I installed the gas strut today.
Big improvement. I should have done this a year ago.
I used a Bahco 2681 rivet gun. It is a good quality tool but marginal for the rivets in the kit. I had to use groove joint pliers to get enough leverage to shear the rivet pin. I'm not sure if the tool would hold up to doing another four rivets.
If I had this to do again, I'd get a bigger rivet gun.
Other than that the install was an easy job.
Post #622170 6th May 2017 5:54pm
JOW240725
Still tempted with one of these. I just have flashes of the kids opening the door and it self opening against a wall or car bonnet parked behind. Shocked James
Instagram @suffolk_rovers
Post #622237 6th May 2017 10:12pm
BobT
United Kingdom 2015 Defender 110 Puma 2.2 USW Santorini Black
I fitted one to my 2015 110 last year and never had any problems at all.
It's one of the best additions I've made, no more having to prop the door open or th door swinging back onto me.
It can be positioned/adjusted so that the spare wheel doesn't come into contact with the rear of the vehicle when open.
Post #622326 7th May 2017 9:20am
Page 2 of 2 <12
