Home > My Defender > Td5 110 csw, Lowered, led's, Tints and Puma seats
Page 41 of 81 <123 ... 404142 ... 798081>
grafty99
There are so many things it could be. Is the turbo actuator free? 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #619874 27th Apr 2017 10:35am
mk1collector
Yes, it's a six month old turbo Thumbs Up Ray
My build thread
Post #619876 27th Apr 2017 10:42am
barbel jim
EGR blanked and disconnected ? Turbo pipes sound, not delaminated ? dose it run ok other than the smoke ??
Post #619879 27th Apr 2017 10:58am
mk1collector
Egr removed, turbo/intercooler hoses replaced with silicon was running great apart from loss of mpg and black smoke. The loss of mpg coupled with being told an injector sounded like it was dragging and black smoke suggesting over fuelling is why we decided to replace the injectors thinking one may be leaking. I replaced the maf sensor a couple of months ago and the map sensor (to rule it out) last week which brought back a little low down torque that I didn't realise was missing. I need to take out the intercooler to check for any splits or leaks. Ray
My build thread
Post #619884 27th Apr 2017 11:16am
barbel jim
Might be worth checking the hose clips, or hoses for movement. The silicon ones are a pita to hold with the standard clips. A while back I had an intercooler hose slowly move and eventually pop off. Smoked like a bitch at times, perfect performance though. Had me stumped for a couple of weeks till it went bang Rolling with laughter Similar symptoms
Post #619886 27th Apr 2017 11:23am
mk1collector
I'll definitely give that a go, thanks for the tip Thumbs Up Ray
My build thread
Post #619909 27th Apr 2017 2:00pm
mk1collector
Well the diesel knock from the new injector has gone as I replaced the injector Rolling Eyes Ray
My build thread
Post #620259 28th Apr 2017 9:20pm
barbel jim
No nearer then Ray??
Post #620268 28th Apr 2017 9:54pm
mk1collector
A bit nearer. The noisey fuel pump has gone so the injector seals definitely needed changing, we'll have to see on the mpg and the black smoke is better but still more than I'd like so I'm checking all pipes, intercooler, air box and everything else this weekend to try and find any air leaks or anything really Ray
My build thread
Post #620386 29th Apr 2017 4:52pm
L110CDL
Hope you find what your looking for Ray Thumbs Up Clayton.
Keeper.
Post #620614 30th Apr 2017 9:05pm
mk1collector
Thanks Clayton Thumbs Up I've got to check over the intercooler and pipes this week sometime to rule them out and see where I go from there Big Cry Ray
My build thread
Post #620872 1st May 2017 9:00pm
L110CDL
Are you going to takes the pipes of one by one to check them or are you going to check them in situ Ray ? Clayton.
Keeper.
Post #620895 1st May 2017 9:48pm
mk1collector
I've taken everything off one by one up to the turbo so far, and the pipes from the turbo onwards are silicon so should be ok but I'll take the intercooler out completely and check it over, so while its out i'll take the hoses off and double check they're fine. If nothing is obvious on the intercooler I'll stick the original back in and see if the smoke has gone just to be doubly sure it's not that. Ray
My build thread
Post #620902 1st May 2017 10:23pm
L110CDL
Good idea Ray, but do check the silicon ones, depends on make they are, but i got some on mine and when the mechanic took my water pipe off he found it coming apart from the inside Shocked not good so had to put a new original hose back on, i had not had them on long, but i had bought them well in advance and the warranty had run out Rolling Eyes Clayton.
Keeper.
Post #620906 1st May 2017 10:30pm
mk1collector
It's a pain when that happens. Mine haven't been on too long but as I got them through the wife's company the hose supplier should honour the warranty if anythings wrong. It's annoying as I don't mind paying to fix the problem but I just can't find it Evil or Very Mad Ray
My build thread
Post #620910 1st May 2017 10:39pm
