Home > Maintenance & Modifications > Tyre sizes, wheel carrier issues (solved) and wheel covers.
I know, I know, tyre's are a bit repetitive to discuss here.
However, looking for a few views - especially as many of you have already done this.
I'm going to get new tyre's soon, I've been running 235/85/R16 KM2's which I could not fault at all.
I'm definitely sticking with KM2's.
However, I have the choice of these again or a bit wider I think upto around 255/85 on the same boost rim with no issues at all.
On this size, are spacers required or not? Would they be a direct fit with no issues?
And lastly I assume they are just within the arches and fully legal.
A couple of issues I'd have, I have no swingaway wheel cover. (Nor do I really want one, especially with bumperettes.)
I'd like to use the standard carrier, I know there can be issues with that but I do have the gas strut so wouldn't that counter some of the weight okay?
How about depth, can spacers be used? If so what dia spacer for the spare wheel to clear the wiper okay?
Lastly, my wheel cover which is a gloss rigid type is 235 in size.
But that is faded a little so I'm sure I can get one the sane talking to a supplier.
I've very tempted to go for it, cost aside but I do have this spare wheel issue.
So the jist is, I want to use the standard carrier, still have a wheel cover. (Light weight anyway.)
NOT have to use spacers on the hubs, but small spacers perhaps needed for the rear door carrier.
Any other issues I should be aware of like wheel bearing load etc?
If there is likely to be issues other than just adding some wheel carrier spacers and a new larger wheel cover I'll just stick with the 235.
Thoughts really appreciated. Thumbs Up ___\â­ï¸Lone|Star|State/___
____\We|Will|Win/___[/size]
____/🇬🇧🇺🇸\____
_//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_
Post #619240 24th Apr 2017 8:26pm
leeds
We run 255/85/16 BFG M/T without spacers on standard suspension and with a 2" lift and do not have issues.
255/85/16 are 33" diameter tyres and a swingaway wheel carrier moves the wheel to the outside but it does clear standard rear lights. With standard door mount there will be plenty of room.
Flat nuts or standard nuts can be used as back spacers if needed on the standard spare wheel mount.
A gas strut should cope with a boost wheel OK. They struggle with a rim like the Hutchinson beadlockers fitted with 255/85/16 as that is an extremely heavy rim.
Brendan
Post #619253 24th Apr 2017 8:51pm
Hi Brendan, excellent to hear.
My main issue now that is clarified. (Thank you)
Will be clearance between tyre and wiper to the rear, what you have mentioned is couple of ideas.
However, they are likely to still be fairly thin I'd have thought and possibly full nuts reduce the available thread a lot.
My issue is compounded a little extra as the wheel cover flange adds a few more mm to catch on the wiper.
Rolling Eyes
However, I have from the past maipulated the wiper arm to sit a bit closer to the body and glass which has helped.
If I'm correct there is a 20mm extra width between 235 & 255.
Whist I have clearance avaible now I'd only need 20mm extra.
I thought maybe an actual road wheel alloy wheel spacer may work well?
They seem to be mostly 30mm though, but what do you think to that?
Surely that'd give the extra dia and full thread combined, and around £40 for one isn't overly pricy for a one off item.
Like this:
http://www.ebay.co.uk/itm/1-x-Bulldog-Allo...SwU-pXrD4b ___\â­ï¸Lone|Star|State/___
____/🇬🇧🇺🇸\____
Post #619307 24th Apr 2017 10:29pm
DSC-off
Hi Steve,
The thin nuts on the carrier bracket can be screwed out to adjust the position of the wheel in/out. When the wheel is fitted and clamped with nuts on the outside it is all secure enough. Alternatively you could put washers behind the thin nuts if you prefer them to be screwed up to something solid.
You will only need an extra 10mm clearance if the tyres are fitted on the same wheel rims. The extra 20mm tyre width is evenly added 10mm on the inside of the rim and 10mm on the outside.
I've recently picked up a Bestop cover for 33" tyres that is a good fit on KM2 255/85.
Bestop part no 61033-35. It appears to be good quality, made from the same vinyl they make soft top covers from, thick and strong. I'll add a picture later.
Post #619392 25th Apr 2017 12:40pm
Oh good, so not as much as an issue then as I first thought.
Thumbs Up
I went for 235's originally as I needed them fast, so didn't have time to mess around or checking figment.
They have however been very very good, just fancy a change now and after getting a tyre cut a while ago it's an ideal time I think to go a little wider and fill the arches a little.
____/🇬🇧🇺🇸\____
Post #619396 25th Apr 2017 12:56pm
There should be no problem at all fitting a 255/85 KM2 on a Boost alloy - for a time I ran 285/75 KM2s on Boosts. The 285s were a very tight fit on the rim and seriously compromised the turning circle, but the 255/85 will fit the rim better and will have less of an adverse effect on TC.
The 255/85 is also, in my opinion, the best performing size and the the best aesthetic size for a Defender.
I run 255/85 KM2s on 0 offset Blindos and there are no protrusion issues, and they're not excessively dirty (unlike the 285/75s). To fit these I had to trim a very small amount of the inside of the ROS wheel arch flare off (curiously only on the offside, the nearside side was OK! Don't you love Defender buld tolerances?) It would be completely impossible to fit tyre chains without serious panel damage with this wheel/tyre combination though.
With Boosts yours would be 33mm further under the arch, so you certainly shouldn't have any problems either with clearance or with crud, although again I think it very unlikely that you'd be able to fit chains.
I can't comment on the wheel carrier since I use a significant;y customised Sonic3D swingaway. You may have trouble finding a wheel cover to fit, they don't seem very easy to find at the moment.
If you are currently running 235s, the 255s are only 20mm wider overall, and therefore will only be 10mm nearer the chassis or nearer the arch. 10mm is not going to cause any major issue.
Post #619403 25th Apr 2017 1:55pm
Can I ask where you found this and how much it cost? Thanks.
Post #619404 25th Apr 2017 1:59pm
Blackwolf - I've used a 'Cutlers' make fir a long time, to been great.
On their site they suggest you can purchase to order size gif a cost lower than you may think.
These are semi rigid gloss but there are other types I think. Thumbs Up ___\â­ï¸Lone|Star|State/___
____/🇬🇧🇺🇸\____
Post #619449 25th Apr 2017 5:23pm
DSC-off
Hi Blackwolf, I got the cover while in the States, from Bestop themselves, they had a stall at the Moab Jeep Safari show.
I got it at a discounted show price of $30, unfortunately they only had one in that size, I would have brought more back. Regular price is $35 + tax, available from, 4wheelparts.com, 4wd.com, quadratec.com
They also have a UK and European dealers.
The quality does seem good, heavy soft top material, so I expect it will last.
The fit is better than it looks in the pictures, and it still has a few creases from being squashed in a suitcase.
It would also fit 285/75/16 for anyone needing that size.
Post #619522 25th Apr 2017 9:17pm
Thon
On an associated note, when I switched from 7.50 x XZL tyres on Wolf rims (roughly 235 size) onto 265/75 Grabbers on Evo Corse Dakars I found that they had much more tendency to tramline and follow the ruts in the road, which I find pretty tiresome on long journeys. You're constantly correcting the steering and it gets old quickly. Pressures are the same as I run on the XZLs and the suspension and steering are all in good order. Really annoying.
Personally I would be loath to go wider than 235s but that's just me and it seems i'm in a huge minority - I just don't see the appeal of anything wider. The grabbers were included with the Dakars so i'm going to use them until the winter then switch over the XZLs again. Irrespective of tread type, wider isn't necessarily better IMHO.
Post #619545 25th Apr 2017 11:02pm
^^ Absolutely right.
I find that the 255/85s are very much more pleasant on the road than the 285/75s were. With the 285s you always had to be aware of the road surface in front of the vehicle and anticipate the steering corrections which were about to be required, but with the 255/85s driving is far more relaxing.
To be honest there's not a lot of difference in this respect between 235s and 255s.
Post #619578 26th Apr 2017 8:01am
Thon
You know I would understand why 285s would be pretty horrible with tramlining, but these 265s seem properly abysmal too - it's such a disappointment, and if i'd paid proper money for them i'd be quite peeved. I've driven a lot of cars over the years and typically find those with wider than standard wheel/tyre combinations are less pleasant to drive. I am talking about older stuff like Mk2 Golf GTI, Skip Brown 205 GTI, Lancia Delta Integrale, Maserati Biturbo, etc but the fact remains that they were all nicer to drive on standard (sized) rubber.
I know many would consider it purgatory, but the sooner i'm back on the 7.50 XZLs the better. They're not too noisy and steer nicely, considering the block pattern. The only fault I really came across was their tendency to slide from the front (understeer) if you really take the Censored , but i'm not a fast driver any more, and particularly not in a 110!
I suspect once the XZLs are done I would go for a BFG A/T K02, partly due to having had the BFG A/T before and particularly now they're dual rated for summer and winter they are much more useful to me. I would be very loath to go above 235s though, based on my current experience.
I've always been a bit puzzled about the benefits, other than aesthetics, of wider wheels/tyres too - my first car had 165/70 x 10 tyres (can you guess what it was?) and when I switched it back to the standard 145s it was much improved in stability and driveability.
Post #619583 26th Apr 2017 8:23am
I think running a narrower MT on road a lot, like I do you tend to get more shoulder wear due to less footprint on the road.
Particularly with loads of roundabouts. Rolling Eyes
They also look a little narrow and don't fill the arches quite as much, but I don't like massive width or it just looks stupid imo.
This is why I like the idea of the 255's as Blackwolf has, and they look really nice and much preform the same way.
They aren't cheap though, but the 235's aren't far behind. Around £860 for 5x fitted I believe.
Hoping to sort this out in around May sometime. Thumbs Up ___\â­ï¸Lone|Star|State/___
____/🇬🇧🇺🇸\____
Post #619612 26th Apr 2017 10:59am
Little update for this thread.
As some of you have been interested in 255/85 wheel covers, I have emailed this company:
http://www.wheelcover.com/public_html/index1.html
Who is the manufacturer of my current wheel cover, I have a gloss semi rigid one but they do soft too.
I have asked for quotes from them for SR and Soft delivered in that size.
If and when I hear back, I'll let you guys know.
I have no connection with this company, but I have been happy with the brand so thought it might be insteresting to ask.
I also mentioned this size isn't on the 🇬🇧 market readily here either.
Will hopefully report back in time. Thumbs Up ___\â­ï¸Lone|Star|State/___
____/🇬🇧🇺🇸\____
Post #619716 26th Apr 2017 8:02pm
Okay, heard back quickly which is good.
Sadly, the gloss type I have they do not do in that size which is a shame.
However, they do do a soft version which most of you are looking for in 255/85 for £55 inclusive delivered.
This is probably what I'll go for. ___\â­ï¸Lone|Star|State/___
____/🇬🇧🇺🇸\____
Post #619880 27th Apr 2017 10:59am
