![]() | Home > Technical > Brakelight Switch |
foxyred Member Since: 16 Jul 2016 Location: Nottingham Posts: 227 ![]() ![]() ![]() |
behind the pedal box near your bulkhead open ended spanner, but check wires first might not be the switch, could be bad earth
JamesF Member Since: 10 Nov 2016 Location: Hitchin Posts: 71 ![]() ![]() ![]() |
Thanks for taking the time to reply.. Where do I access the pedal box from.. underbeath or is it behind the master brake gubbins?
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2362 ![]() ![]() ![]() |
Open your bonnet and stand at the offside near the hinge. In front of you you'll see the servo ( the upright circular box) and the brake master cylinder with its fluid reservoir on top. At the back of the assembly by the bulkhead you'll see a switch with 2 wires going into it. This is the brake switch 😊
Thanks Mo. Sorted and was a broken wire near the switch. All sorted now. Thanks again all.
