Home > Technical > Brakelight Switch
JamesF
United Kingdom 1989 Defender 90 2.5 TD HT Baltic Blue
Brakelight Switch
Hi all
It seems neither of my brakelights are working.
The fuse seems to be ok and the bulbs work. Is it possible the brake light switch has gone?
Trouble is I am not sure where it is located?
I think it maybe in the pedal box but that looks inaccesable to me:(
I have a 1989 defender
Thanks
Post #616717 14th Apr 2017 8:40am
foxyred
England 1994 Defender 90 200 Tdi HT Montalcino Red
behind the pedal box near your bulkhead open ended spanner, but check wires first might not be the switch, could be bad earth
Post #616720 14th Apr 2017 8:49am
JamesF
Thanks for taking the time to reply.. Where do I access the pedal box from.. underbeath or is it behind the master brake gubbins?
Post #616726 14th Apr 2017 8:58am
Mo Murphy
Open your bonnet and stand at the offside near the hinge. In front of you you'll see the servo ( the upright circular box) and the brake master cylinder with its fluid reservoir on top. At the back of the assembly by the bulkhead you'll see a switch with 2 wires going into it. This is the brake switch 😊
50 Shades of Pennine Grey
Post #616802 14th Apr 2017 5:15pm
JamesF
Thanks Mo. Sorted and was a broken wire near the switch. All sorted now. Thanks again all.
Post #617163 16th Apr 2017 8:44am
