Home > Tdi > Ashcroft higher 5th gear option on R380
Page 3 of 3 <123
Discoverys had smaller tyres, which affected the overall ratios. Darren
Post #616352 12th Apr 2017 5:31pm
nosnibod
United Kingdom 1998 Defender 110 300 Tdi SW Bronze Green
Smaller tyre diameter - for example 235/70R16 lowers the gearing by nearly 10% compared to 235/85R16. Dave
Green Goddess - 1998 Defender 110 300tdi
Post #616356 12th Apr 2017 5:56pm
Mo Murphy
The Discovery had smaller tyres and thus a smaller diameter. The higher transfer gearing compensated for this.
50 Shades of Pennine Grey
Post #616373 12th Apr 2017 6:48pm
MJN110
United Kingdom 2016 Defender 90 Puma 2.2 Landmark LE Montalcino Red
Thank you all for the latest information.
I am beginning to think I should keep my transfer box standard and experiment with different tyre sizes.
Does anybody know what size tyres a new Discovery 300tdi had fitted from the factory?
Post #616695 14th Apr 2017 6:52am
geobloke
235/70/16 on ours.
Post #616707 14th Apr 2017 8:06am
madmac
United Kingdom 1996 Defender 110 300 Tdi HT Alaska White
Give Shabs @ Syncro Gearboxes a call.
I've just had a rebuilt box from him with the higher 5th in my 110 300TDi can't say much at the moment as its only been in a week.
Also had the slick shift and that is great.
So far it does seem much better cruising on the A50 although as already mentioned you need to be running faster before changing up to 5th from 4th due to the increase.
Tyres are currently Copper STT 265/75 R16 but I also have a set of General Grabber 235/85 R16 but not had these on.
I also have a full width Alisport intercooler but I need to check the fuel pump tuning as I think it currently is stoke after a new pump was fitted and I forgot to adjust it.
Post #625499 19th May 2017 10:54pm
madmac
Post #625500 19th May 2017 10:55pm
Bren_bruce_20
United Kingdom 1997 Defender 90 300 Tdi CSW Santorini Black
MJN110 did you ever get round to fitting the 1.2 transfer box to your 300tdi 90? Looking at doing this myself to a completely standard 1997 300tdi. Cheers
Post #986732 25th Mar 2023 8:47am
MattH268
United Kingdom 2013 Defender 110 Puma 2.2 HCPU Fuji White
I'm following with interest as my 300tdi 90 will need a new gearbox soon as the syncro 1st to 2nd is troublesome again and 5th is noisy.
My current plan is to fit an Ashcroft R380 standard gearbox but with the HD rear support bearings and a new Ashcroft 1.2 gear ratio transfer box with sleaved casing, oem intermediate shaft & rear output shaft later this year.
Since having a complete restoration & rebuild a few years ago to include an Allisport full size intercooler, steg supplies boost pin, timing spacer kit plus some other tweaks I find I can sit in 5th way more. I don't tow or drive much offroad these days, my nearest motorway in 150+ miles away, it's on a 2" lift and has 265/75/16 tyres. My 90 is used primarily to explore the Highlands & Islands which it's great at. The current original transfer box is likely totally fine, but for me I think the 1.2 ratio will work better for me touring with the extra performance my 90 has.
M 300tdi 90 CSW
2.2tdci 110 HCPU
1972 Series 3 88" Truck Cab
Post #986791 25th Mar 2023 5:33pm
Page 3 of 3 <123
