Home > Puma (Tdci) > Check your heater hoses...
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Just had a 2010 90 brought in to the workshop due to a coolant leak,
The problem was the bottom hose from the heater matrix rubbing against the red lifting eye.
I know it's been talked about in the past, but well worth having a quick look under your bonnet just in case yours may be doing the same?
Along with sorting the pipe, the customer was happy for me to remove the lifting eye to prevent further trouble.
 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #616520 13th Apr 2017 1:11pm
shaggydog
Wasn't there a recall for that lifting eye to be removed? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #616521 13th Apr 2017 1:13pm
ian series 1
Not sure Shaggy?
My 08 still has one, and I've never seen any with them missing as yet? 80" 80" 86" 88" 90"
Post #616527 13th Apr 2017 1:30pm
slightly different layout in LHD's for anyone following Thumbs Up
Post #616532 13th Apr 2017 1:49pm
JOW240725
Thumbs Up James
Instagram @suffolk_rovers
Post #616546 13th Apr 2017 2:48pm
jst
great, thank you for posting will check Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #616673 13th Apr 2017 10:27pm
I think there was a recall..
Mine however, still has the bracket and I've checked mine and no issues.
Seems to affect some, and not others.
Turbo hose clearance between it and the steering shaft is another to watch.
Thumbs Up ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #616675 13th Apr 2017 10:33pm
No recall for that, although the more common problem was the bracket working loose and rattling or falling off. Many brackets either fell off or were taken off for that reason.
Post #616676 13th Apr 2017 10:37pm
X4SKP
Thanks ian series 1... Thumbs Up
I have a MY2011 90 and will check tomorrow...but I've been all over mine and are currently convinced that I don't have this lifting eye fitted, mines a Dec 2010 registered model...so maybe this was dropped at some point... SKIP
Post #616677 13th Apr 2017 10:39pm
zsd-puma
It might have been a TSB (i've not checked) rather than a recall.
These are just where LR have identified a common problem and found a solution, but owners of vehicles aren't specifically notified unless they report the issue or it's found at the time of a routine service.
Post #616686 13th Apr 2017 11:58pm
zsd-puma
It's possibly an item that was used for assembly, but supposed to be removed once the engine was dropped onto the chassis, but on some they probably forgot.
Post #616687 13th Apr 2017 11:59pm
andydef90
United Kingdom 2014 Defender 90 Puma 2.2 HT Corris Grey
ill have a look today thank you
Post #616731 14th Apr 2017 9:30am
ian series 1
It does seem a bit odd?
I've just checked mine and the hose is a good inch away from the lifting eye,
Whereas the one I did yesterday was very tight to the bracket?
There is only one hose listed, so not sure why some do and some don't?
Maybe down to whoever fitted them at the factory? 80" 80" 86" 88" 90"
Post #616737 14th Apr 2017 9:58am
