![]() | Home > Maintenance & Modifications > Cubby strut - which one? |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1789 ![]() ![]() ![]() |
It's Newtons (N) not Newton Metres (Nm)
One a measure of force, the other a measure of torque. Either way, it's a 60n strut, meaning it has 60N (or 6kg on earth) of "push" |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3865 ![]() ![]() |
^ Thanks
![]() Does 60 sound correct or still too high? |
300TDi CSW Phil Member Since: 03 Apr 2016 Location: Bracknell Posts: 860 ![]() ![]() ![]() |
What sort of size and type of cubby box are you talking about?
If it is the standard LR or Exmoor (various others) with the ply lid and padding then the Lid itself will weigh a minimal amount (probably sub 1Kg. Is the strut just to keep it raised or actually raise it once past a certain point etc? 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper. Wide Track Sankey- In bits- Gone to a new home M0XQS |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4332 ![]() ![]() ![]() |
Mine is a 60N one and I'm happy with it. 2007 110 TDCi Station Wagon XS
Hello
Its a FCX Padded one, but light in weight anyway, It more to make it feel a bit more secure than the current webbing? and so it can stay up while using the cubby. Thanks |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2296 ![]() ![]() ![]() |
I have a 50N fitted to the padded lid of the Exmoor Trim XS/Premium cubby box.
It's spot on ![]() It assists both the opening and closing and helps prevent it being opened/strained too far by 'others' in the truck ![]() I recall it was 99p off eBay. |
