Home > Technical > DAB Aerial
Butchers Boy
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
DAB Aerial
I want to replace my aerial on my 90 with a DAB aerial preferably in the front wing any suggestions? 2010 Defender 90 HT
The longer I live..... The better I was!
Post #593480 16th Jan 2017 11:33am
BigRuss
Jvc bee-sting type dual dab and fm arial works well Russell
2011MY 110 XS USW Black
Post #593499 16th Jan 2017 1:27pm
Nipalong
England 2015 Defender 90 Puma 2.2 SW Corris Grey
Looking to have a DAB radio put into my Defender, looks like you can get a booster, which means you can use the original ariel
Post #612346 26th Mar 2017 9:05pm
adbseries3
England 1999 Defender 90 V8 Petrol 50th Auto Atlantis Blue
I bought a Kinetic 6006 (I think) from DAB on Wheels, to use with a new Alpine. The sound and reception are fantastic. Said best on roof but I wing mounted.
Post #612940 28th Mar 2017 9:24pm
Morepower
New Zealand
I've got the same unit.. std wing mounted aerial connected to a Alpine CDE136BT... Excellent reception and signal quality... So much so that I fitted it to the 90 also..
Regards
Tim It doesn't matter how bad it is, It can always get worse...
2013 Bowler 110 (Sold)
2016 Bowler 90 Rally Spec (Sold)
Post #613142 29th Mar 2017 9:12pm
rustandoil
I bought this, way better than the stick on aerial I had
http://www.caraudiodirect.co.uk/dab/antenn...l-splitter
Post #613223 30th Mar 2017 9:41am
Chopperone
Slight hijack of thread - I am looking for a black flexible FM aerial to mount on the wing.
Used to be known as a "full wave antenna " as opposed to a half wave antenna which is what most now are i.e about 30cms in length whereas a full wave would be about 60cm +.
Just can't seem to find one
Any ideas?
Guy May your life be like toilet paper ; long & useful.
Post #613809 1st Apr 2017 5:18pm
Moles
Was that easy enough to fit, i.e. getting the old unit out.
I think, on the Puma anyhow, it's tough to get to the standard aerial fixings.
Moles
Post #613812 1st Apr 2017 5:33pm
zsd-puma
Any ideas?
Guy
I've got the Hirschman FM aerial.
http://www.4x4overlander.com/product/hirsc...-defender/
Not cheap, but superb quality. Has stainless/anodised ally fittings so it'll last for ever and designed to fit the factory wing hole.
The actual aerial is coiled around the mast, so it's actually longer than the mast. which is 47cm ish.
Post #613841 1st Apr 2017 8:21pm
Riverboy
2014 Defender 90 Puma 2.2 SW Corris Grey
The garage fitted this DAB aerial for me last year along with everything else during its big makeover. No idea what make etc but it looks great. No DAB outside of Paris in France so useless to me but hey Rolling Eyes It worked great in the UK while I was there. I can give you their number if you like. Its FM as well but I always use Apple Carplay for radio in the cars.
Post #613850 1st Apr 2017 8:32pm
Sadi
Namibia 2016 Defender 110 Puma 2.2 Heritage Edition SW Grasmere Green
These threads may help ..
Post #613853 1st Apr 2017 8:39pm
Chopperone
I am struggling to spend 90 quid on an aerial....
Bosch auto flex no longer exists as far as I can see. No straight flexible Hirschmann on Amazon nor for that matter on eBay
Seems strange that the market is so limited May your life be like toilet paper ; long & useful.
Post #613931 2nd Apr 2017 7:36am
zsd-puma
I must admit i thought the same before biting the bullet, but it's well worth it for the quality, you'll never need to buy another. Even if the mast gets nicked you can buy replacement masts.
It also came with a good quality earth lead to run from the aerial base to a proper earthing point, rather than scraping paint off around the aerial hole (which promotes rust) and trying to get decent earth through a bolt on ally panel.
FM reception is like night and day compared to the OEM ones.
Most cars have them factory fitted these days, either on the roof or on glass. Most people aren't going to fit a bendy rubber or fibreglass one on a 30 year old classic car, anything younger than that likely came with something as standard.
Post #613944 2nd Apr 2017 8:54am
