![]() | Home > Technical > DAB Aerial |
Butchers Boy Member Since: 10 Jan 2016 Location: Essex Posts: 426 ![]() ![]() ![]() |
I want to replace my aerial on my 90 with a DAB aerial preferably in the front wing any suggestions? 2010 Defender 90 HT
The longer I live..... The better I was! |
Jvc bee-sting type dual dab and fm arial works well Russell
2011MY 110 XS USW Black |
adbseries3 Member Since: 27 Apr 2016 Location: sussex Posts: 49 ![]() ![]() ![]() |
I bought a Kinetic 6006 (I think) from DAB on Wheels, to use with a new Alpine. The sound and reception are fantastic. Said best on roof but I wing mounted.
Morepower Member Since: 08 Jan 2013 Location: Fife, Scotland Posts: 630 ![]() ![]() |
I've got the same unit.. std wing mounted aerial connected to a Alpine CDE136BT... Excellent reception and signal quality... So much so that I fitted it to the 90 also..
Regards Tim It doesn't matter how bad it is, It can always get worse... 2013 Bowler 110 (Sold) 2016 Bowler 90 Rally Spec (Sold) |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 865 ![]() ![]() ![]() |
I bought this, way better than the stick on aerial I had
http://www.caraudiodirect.co.uk/dab/antenn...l-splitter |
Chopperone Member Since: 13 Nov 2016 Location: Derbyshire Posts: 396 ![]() ![]() |
Slight hijack of thread - I am looking for a black flexible FM aerial to mount on the wing.
Used to be known as a "full wave antenna " as opposed to a half wave antenna which is what most now are i.e about 30cms in length whereas a full wave would be about 60cm +. Just can't seem to find one Any ideas? Cheers Guy May your life be like toilet paper ; long & useful. |
Moles Member Since: 17 Mar 2016 Location: Wiltshire Posts: 40 ![]() ![]() |
Was that easy enough to fit, i.e. getting the old unit out. I think, on the Puma anyhow, it's tough to get to the standard aerial fixings. Moles |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
I've got the Hirschman FM aerial. http://www.4x4overlander.com/product/hirsc...-defender/ Not cheap, but superb quality. Has stainless/anodised ally fittings so it'll last for ever and designed to fit the factory wing hole. The actual aerial is coiled around the mast, so it's actually longer than the mast. which is 47cm ish. |
Riverboy Member Since: 16 May 2016 Location: French sector, Earth Posts: 1288 ![]() ![]() |
The garage fitted this DAB aerial for me last year along with everything else during its big makeover. No idea what make etc but it looks great. No DAB outside of Paris in France so useless to me but hey
![]() ![]() Click image to enlarge |
Sadi Member Since: 23 Jul 2015 Location: Windhoek Posts: 334 ![]() ![]() ![]() |
I am struggling to spend 90 quid on an aerial....
Bosch auto flex no longer exists as far as I can see. No straight flexible Hirschmann on Amazon nor for that matter on eBay Seems strange that the market is so limited May your life be like toilet paper ; long & useful. |
I must admit i thought the same before biting the bullet, but it's well worth it for the quality, you'll never need to buy another. Even if the mast gets nicked you can buy replacement masts. It also came with a good quality earth lead to run from the aerial base to a proper earthing point, rather than scraping paint off around the aerial hole (which promotes rust) and trying to get decent earth through a bolt on ally panel. FM reception is like night and day compared to the OEM ones.
Most cars have them factory fitted these days, either on the roof or on glass. Most people aren't going to fit a bendy rubber or fibreglass one on a 30 year old classic car, anything younger than that likely came with something as standard. |
