Home > Technical > Air Intake Box Removal
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
Hi,
Just been trying to remove the air intake box on my Puma to get at the plastic cap over the suspension strut.
I can't work out how it's fixed on - any ideas?
Thanks
BM52 BM52
Post #61251 27th Feb 2011 9:38am
K9F
BM52,
From what I remember (memory not as good as it should be so check carefully) from fitting my Safari snorkel I think you need to drill out the heads of the 6 pop rivets at the bottom of the airbox, visible with the filter removed! Thumbs Up
Hope this helps! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #61253 27th Feb 2011 10:14am
bm52
KF9 - thanks, i can't see any rivets from inside the box. the box is plastic and looks molded to the shape of the inner wing, half covering the the turret cap. i assume there has to be a simple way! currently foxed Confused
Thanks BM52
Post #61261 27th Feb 2011 11:03am
Glynparry25
Have you got A/C? The reason why I ask is that if you do you will have to remove the whole inner wing to remove the box.
L/R way of removing it is to undo the 3 bolts which are inside the arch that bolts the lower airbox mount and then you pull it out of the rubber bungs that hold it to the top of the arch..... Hard to explain. But you don't need to drill the rivets.
Glyn Dog Sheep
Post #61265 27th Feb 2011 12:46pm
cobs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Cairns Blue
LR pdf of air intake box removal (courtesy of dgardel) in my gallery. Page 9 shows diagram of 3 bolts that Glyn refers to. LR instructions are fine if you just happen to have a fully equipped LR workshop to remove air con refrigerant!
Post #61274 27th Feb 2011 1:39pm
bm52
Thanks for the PDF, i'll have a look after the rugby.
All I am trying to do is get access to the top of the damper so I can swap it out for a new one.
The only issue is one screw holding on the turret cap, if I undo the rear one I can twist the cap down but not enough to give me access to the top of the damper. After seeing the PDF I was wondering whether I can detach the dirty air feed to the bottom of the air box thus giving me room to swing the cap out of the way.
What should have been a fairly quick job it turning into a bit of a mission. Big Cry BM52
Post #61294 27th Feb 2011 3:44pm
mse
Removing the air box to fit the safari and seal it up.
Remove rivets and pull the airbox off the bracket - you dont need to unbolt it...just pull hard. Mike
Post #61300 27th Feb 2011 4:50pm
bm52
will i need to replace the rivets?
on the other hand, just seen on the internet that you can remove the turret and shock from under the wing without removing the plastic cap?
has anyone tried this method?
thanks BM52
Post #61324 27th Feb 2011 8:03pm
mse
Yes with 6 standard rivets. Mike
Post #61326 27th Feb 2011 8:16pm
AndrewS
I thought you just disconnected the in and out pipes the air sensor and simply pulled ? 130's have feeling's as well you know Smile
Post #61331 27th Feb 2011 8:49pm
BigMike
hold on, you dont need to take out the airbox. you just need a set of narrow mole grips to get onto the flat of the top of the damper. i've changed shocks twice and not had to do that. second time put on open turrets to make life even simpler
Post #61337 27th Feb 2011 9:14pm
fordy103
2010 Defender 90 Puma 2.4 HT Zermatt Silver
depends if your fitting extended strut turrets and longer shocks? personally, instead of removing the airbox when fitting my gwyn kit, i just removed the easy screw, and pulled the cover off, with the none accesable screw still in place. Then when refitting just drilled another hole that you can actually access, and refitted another self tapper.
Job done
Post #61342 27th Feb 2011 9:35pm
B4Lamb
Wales 2007 Defender 90 Puma 2.4 HT Galway Green
Similar to above I was able to grip the awkward self tapping screw (sharp end) from underneath the wing using good mole grips.
I unscrewed it till only a tiny pip was left and not enough to grip. Then a tap with a hammer and blunt punch the the self tapper popped out.
As above for replacing the cover, drill a new hole close to the offending one from under the wing and fit a stainless steel self tapper from the underside that is much more accessible to undo from under the wing. "You are never to old to learn something new"
Post #966511 3rd Oct 2022 4:15pm
