![]() | Home > Technical > Air Intake Box Removal |
BM52,
From what I remember (memory not as good as it should be so check carefully) from fitting my Safari snorkel I think you need to drill out the heads of the 6 pop rivets at the bottom of the airbox, visible with the filter removed! ![]() Hope this helps! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
KF9 - thanks, i can't see any rivets from inside the box. the box is plastic and looks molded to the shape of the inner wing, half covering the the turret cap. i assume there has to be a simple way! currently foxed
![]() Thanks BM52 |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
Have you got A/C? The reason why I ask is that if you do you will have to remove the whole inner wing to remove the box.
L/R way of removing it is to undo the 3 bolts which are inside the arch that bolts the lower airbox mount and then you pull it out of the rubber bungs that hold it to the top of the arch..... Hard to explain. But you don't need to drill the rivets. Glyn ![]() ![]() |
cobs Member Since: 12 Jun 2008 Location: North Yorkshire Posts: 336 ![]() ![]() ![]() |
LR pdf of air intake box removal (courtesy of dgardel) in my gallery. Page 9 shows diagram of 3 bolts that Glyn refers to. LR instructions are fine if you just happen to have a fully equipped LR workshop to remove air con refrigerant!
Thanks for the PDF, i'll have a look after the rugby.
All I am trying to do is get access to the top of the damper so I can swap it out for a new one. The only issue is one screw holding on the turret cap, if I undo the rear one I can twist the cap down but not enough to give me access to the top of the damper. After seeing the PDF I was wondering whether I can detach the dirty air feed to the bottom of the air box thus giving me room to swing the cap out of the way. What should have been a fairly quick job it turning into a bit of a mission. ![]() |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5117 ![]() ![]() ![]() |
Removing the air box to fit the safari and seal it up.
Remove rivets and pull the airbox off the bracket - you dont need to unbolt it...just pull hard. Mike |
will i need to replace the rivets? on the other hand, just seen on the internet that you can remove the turret and shock from under the wing without removing the plastic cap? has anyone tried this method? thanks BM52 |
Yes with 6 standard rivets. Mike
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3711 ![]() ![]() ![]() |
I thought you just disconnected the in and out pipes the air sensor and simply pulled ? 130's have feeling's as well you know
hold on, you dont need to take out the airbox. you just need a set of narrow mole grips to get onto the flat of the top of the damper. i've changed shocks twice and not had to do that. second time put on open turrets to make life even simpler
fordy103 Member Since: 22 Dec 2010 Location: preston lancs Posts: 85 ![]() ![]() |
depends if your fitting extended strut turrets and longer shocks? personally, instead of removing the airbox when fitting my gwyn kit, i just removed the easy screw, and pulled the cover off, with the none accesable screw still in place. Then when refitting just drilled another hole that you can actually access, and refitted another self tapper.
Job done |
B4Lamb Member Since: 21 Mar 2015 Location: Abergavenny, Wales Posts: 233 ![]() ![]() ![]() |
Similar to above I was able to grip the awkward self tapping screw (sharp end) from underneath the wing using good mole grips.
I unscrewed it till only a tiny pip was left and not enough to grip. Then a tap with a hammer and blunt punch the the self tapper popped out. As above for replacing the cover, drill a new hole close to the offending one from under the wing and fit a stainless steel self tapper from the underside that is much more accessible to undo from under the wing. "You are never to old to learn something new" |
