Home > Puma (Tdci) > Volume Control Valve - Ford part no?
Page 5 of 9 <123456789>
Gonarezhou
South Africa 2015 Defender 110 Puma 2.2 SW Alaska White
If we had a "head banging" emoticon ..... I would use it now! Rolling Eyes
Post #604075 22nd Feb 2017 11:12pm
meeerrrk
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
Did anyone order, receive and fit a valve from diesel parts online shop? My 90 Project : http://www.defender2.net/forum/topic52774.html
Post #612860 28th Mar 2017 3:23pm
JOW240725
Banging Head Banging Head Banging Head James
Instagram @suffolk_rovers
Post #612864 28th Mar 2017 3:30pm
Martin
Site Admin
What, this one? Banging Head
(been here since day 1) Wink  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #612866 28th Mar 2017 3:30pm
TopQ1967
Netherlands 2012 Defender 130 Puma 2.2 HCPU Buckingham Blue
Still not fitted the valve.
The latest updated type of 2.2 VCV valve has a filter at the front. But due to its design it doesn't fit with the filter attached to a (probably) 2012 MY 2.2 engine. Probably, as the engine was swaped mid 2015 due to a oil pump failure.
Post #613090 29th Mar 2017 4:18pm
tobz102
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
Just if anyone needed more positive reviews of replacing the vcv, I did mine yesterday and wow.
My chosen tool combination was a 5mm Allen key bit (10mm bit size) fitted into a 10mm rachet spanner with a flexi end. Literally took 15mins to take old one out and put the new one in - removing nothing else. Took it to main dealer today be recalibrated.
£50 calibration, £60 part.
Improvements include:
Fuel consumption, off boost engine pick up, steady idle. It generally sounds much healthier through the gears.
Post #613343 30th Mar 2017 6:09pm
B4Lamb
Wales 2007 Defender 90 Puma 2.4 HT Galway Green
Out of interest did it run ok after fitting the valve and before getting it calibrated (pilot learn)? I didn't get to have my new valve calibrated and I'm now out of the country for a month but I drove the defender all the way from UK to Spain via Dover towing a boat and it's working perfectly with 30 mpg average for the whole trip. Maybe I was lucky and the old cal settings match the new valve? "You are never to old to learn something new"
Post #613531 31st Mar 2017 10:06am
B4Lamb
yes I did for my 2.4 Puma. All was good. "You are never to old to learn something new"
Post #613533 31st Mar 2017 10:08am
helmutk
Austria 2011 Defender 110 Puma 2.4 SW Tamar Blue
Internet lore tells that the calibration irons out tolerances in manufacture (and so optimizes mpg, responsiveness, whoknowswhat...).
Post #613543 31st Mar 2017 10:38am
meeerrrk
thanks, I will give one a go I think. My 90 Project : http://www.defender2.net/forum/topic52774.html
Post #613562 31st Mar 2017 11:41am
Gonarezhou
Rolling with laughter Banging Head Banging Head Banging Head Banging Head Banging Head
Post #613610 31st Mar 2017 4:23pm
kirk
United Arab Emirates 2009 Defender 110 Puma 2.4 SW Blenheim Silver
After experiencing engine power issues without any engine fault codes, I found this thread (thank you!).
I ordered and I received the UK Diesel Parts VCV and now I am preparing to do the the VCV swap, but I have a question...or two.
(1) Do I need to remove the current BAS remap and go back to the original factory map before I swap out VCV?
(2) Is the second generation 'Bell Auto Service Remote Remap Control' (BAS2 RRC) capable of performing the VCV 're-learn' process?
Once the job is complete, I will report back on the success/failure, tools, remap/relearn, and suitability of the UK Diesel Parts VCV valve.
Thanks in advance for any advice you can provide.
Kirk
Post #615986 11th Apr 2017 9:48am
agentmulder
Kuwait
1: Needs to happen for part 2, so yes, may as well do it before the swap.
2: Yes, it's the same two functions you did before programming the original BAS remap. One doesn't appear to do much at all, the other plays around with the engine idling and bothers your neighbors.
(3: Apply BAS remap again 😆🤖) Solved the bowel problem, working on the consonants...
Post #615988 11th Apr 2017 9:59am
helmutk
VCV calibration should be done on the factory map:
https://bellautoservices.co.uk/help-faq/ba...4tdci/vcv/
Edit: Outrun by agentmulder!
Post #615989 11th Apr 2017 10:01am
kirk
OK. thanks for your responses. I'll give it a go and keep you posted.
Post #616002 11th Apr 2017 10:47am
