Home > My Defender > Defender 90 LS/6L80 conversion. step by step!
Page 7 of 9 <123456789>
bogwert
Scotland 2003 Defender 90 Td5 CSW Zambezi Silver
Really impressive. Shocked
Excellent read! The dials look very nice. Thumbs Up Chris
2014 Discovery 4 TDV6 HSE
2003 Defender 90 TD5 CSW
Post #601444 13th Feb 2017 2:03pm
Peter Td4
Belgium 2008 Defender 110 Puma 2.4 HCPU Santorini Black
Beautiful CNC parts Thumbs Up
Congrats on an amazing build. Peter,
Defender 110 StaWa - Td5
Defender 110 HCPU - Puma
Defender 90 Soft Top - Td5
Post #601679 14th Feb 2017 7:33am
psimpson7
Australia 2014 Defender 90 Puma 2.2 XS CSW Loire Blue
This has been a bit delayed as I spent 2 weeks in Queenstown Mountain biking which got in the way of progress along with also being in the middle of fairly major house renovations but I have an update...!
I picked up the oil pressure sensor adaptor and the fuel system parts and did a quick test assemble on the table.
I have also ordered some of the exhaust parts including the cats and silencer. With a bit of luck I may have it running by this weekend. (without an exhaust)
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  2001 90 HT 6.0LS/6spdAuto.
2003 90 td5 soft top.
2014 90 XS SW 2.2.
Post #611350 22nd Mar 2017 11:08am
Awesome job Pete, fingers crossed on it running this weekend.
Thanks for your advice on the speedo, they changed my order and I'm waiting patiently Thumbs Up QRZ M8VPF
Post #611436 22nd Mar 2017 7:04pm
psimpson7
It starts! Very Happy
Will try and get a short video up tomorrow.
I have one but its been a long day and seemingly I am too tried to work the internet tonight! 2001 90 HT 6.0LS/6spdAuto.
2014 90 XS SW 2.2.
Post #612517 27th Mar 2017 12:45pm
Looking forward to it Thumbs Up QRZ M8VPF
Post #612597 27th Mar 2017 5:48pm
L110CDL
Great news Thumbs Up Clayton.
Keeper.
Post #612701 27th Mar 2017 9:44pm
psimpson7
Hope this works.
First start....
2014 90 XS SW 2.2.
Post #612764 28th Mar 2017 2:41am
Pickles
Sounds promising,.....need to hear a bit more of it when those 8 cylinders are working a bit harder!
Pickles.
Post #612766 28th Mar 2017 4:25am
That'll do! Bow down QRZ M8VPF
Post #612771 28th Mar 2017 6:33am
Romadog
Well its a start..... Rolling with laughter
Looking forward to more...... Thumbs Up
Post #612892 28th Mar 2017 6:56pm
psimpson7
I can't really explain how loud it is with only manifolds, and no cats, silencers, pipes etc.
It sounds a bit like thunder and bearing in mind it was quite late I wasn't really willing to Censored off my neighbors!
It scared the crap out of our dog!
It also didn't have any coolant/water in it.
Most of that will be sorted at the weekend. 2001 90 HT 6.0LS/6spdAuto.
2014 90 XS SW 2.2.
Post #612987 29th Mar 2017 4:47am
bogwert
It's alive! Brilliant! Very Happy
I'm sure the neighbors will get over it! Laughing Confused Chris
Post #613021 29th Mar 2017 10:20am
L110CDL
That sounded great Thumbs Up Cant wait when you get the exhausts on and hear that burble Whistle Clayton.
Keeper.
Post #613152 29th Mar 2017 9:36pm
psimpson7
Bit more of an update.
I have sorted the electrical issue I had. I had accidentally connected the IGN power feed for the loom/ecu etc to the accessories terminal on the key.
When the ignition was turned on power got to the pump to prime etc (as both IGN and ACC are live) but it dropped as soon as it was turned to start as the accessories power is killed during starting so it turned over but had no fuel supply or spark. (I bridged the relay initially to get it running)
Swapping the feed to the IGN terminal on the key as opposed to the ACC terminal has resolved that and the fact that the start inhibit didn't seem to work.
That now all works perfectly.
I have all the gauges working correctly, including the canbus water temp (tested it by heating the sensor in hot water to make sure) and canbus oil pressure gauges. Had about 50psi on start up from memory.
I haven't got the canbus voltmeter connected yet (mainly as I am not sure where to put it!), but it is charging correctly when i multimetered the battery terminals
I have an issue with the throttle where it doesn't work.
The loom is set for the corvette pinout in the connector but the Lokar pedal and loom tail/connector appears to be either camaro or truck configuration.
It looks like one of the 5v supplies and I assume corresponding low is switched around.
This was my wiring diagram!
I removed the short loom between the pedal and the main loom and switched those 2 terminal pins. They were a total pain to remove. I normally manage to get them out with a sewing needle/pin but these weren't going anywhere.
I ended up making a special tool out of a split pin! I had to hold the tool in a bench vice to be able to push the pins out
I have reassembled everything but as of yet haven't tried it so don't know if it is working yet.
Also the auto functions all seem to work perfectly along with the gear indicator. In manual mode I can shift it from 1st-6th with the corresponding correct display on the indicator.
2014 90 XS SW 2.2.
Post #616191 11th Apr 2017 11:55pm
