Home > Maintenance & Modifications > Bent Air vent flap
Rosewellian
Bent Air vent flap
Any tips on how to get this flap to fit close properly. It seems one half of right hand side hinge is bent down. With it in situ I've tried tapping it upwards with hard mallet but no luck and don't want to hit it too hard in case the spot welds break.
Please excuse the pigeon poo on bonnet!
Post #610932 20th Mar 2017 7:35pm
Rallymental
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Santorini Black
It looks to me like the pin on the left is bent?
If it is, try this:
http://www.lrparts.net/defender-stainless-...13654.html The definition of insanity is doing the same thing over and over again but expecting different results.
Solihull, 1948 - "If we paint the chassis, it will last for years"
Solihull, 2015 - "If we paint the chassis.............................
Post #610934 20th Mar 2017 7:39pm
Rosewellian
Thanks I will order a set
Post #610937 20th Mar 2017 7:44pm
mk1collector
It looks to me like the hinge on the right hand side that is welded to the flap has had the pin hole rolled over. I'd take the flap of and with some grips, unroll the pin holder until it's level with the other. Ray
My build thread
Post #610941 20th Mar 2017 7:51pm
grafty99
^ what Ray said Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #610964 20th Mar 2017 8:49pm
L110CDL
+2 ^ ^ Thumbs Up Clayton.
Keeper.
Post #611015 20th Mar 2017 10:06pm
alwoodley72
England 2008 Defender 130 Puma 2.4 HCPU Alaska White
+3^^^^! Then you just need to replace the 'screen rubber.....
Cheers. Alex 98 300 tdi 90 project
88 200tdi project soft top
96 disco 1 jap import
79 911 sc
08 130 double cab utility
Post #611066 21st Mar 2017 12:14am
Rosewellian
Thanks guys looks like I will be having a busy weekend! Vent Flap, windscreen Rubber & windscreen to bulkhead foam seal!
Post #611239 21st Mar 2017 10:22pm
