![]() | Home > Maintenance & Modifications > Bent Air vent flap |
Rallymental Member Since: 17 Aug 2015 Location: The Garden of England Posts: 468 ![]() ![]() ![]() |
It looks to me like the pin on the left is bent?
If it is, try this: http://www.lrparts.net/defender-stainless-...13654.html The definition of insanity is doing the same thing over and over again but expecting different results. Solihull, 1948 - "If we paint the chassis, it will last for years" Solihull, 2015 - "If we paint the chassis............................. |
Rosewellian Member Since: 19 Mar 2017 Location: Hampshire Posts: 7 ![]() ![]() |
Thanks I will order a set
It looks to me like the hinge on the right hand side that is welded to the flap has had the pin hole rolled over. I'd take the flap of and with some grips, unroll the pin holder until it's level with the other. Ray
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4801 ![]() ![]() ![]() |
^ what Ray said
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10994 ![]() ![]() |
+2 ^ ^
alwoodley72 Member Since: 14 Mar 2010 Location: salisbury, wilts Posts: 728 ![]() ![]() ![]() |
+3^^^^! Then you just need to replace the 'screen rubber.....
Cheers. Alex 98 300 tdi 90 project 88 200tdi project soft top 96 disco 1 jap import 79 911 sc 08 130 double cab utility |
Thanks guys looks like I will be having a busy weekend! Vent Flap, windscreen Rubber & windscreen to bulkhead foam seal!
