Home > Puma (Tdci) > Driver Door Lock Barrel Warranty?
Farmerben
United Kingdom 2015 Defender 90 Puma 2.2 HT Keswick Green
As my 2015 defender doesn't have any of this fancy shmancy remote central locking, I'm forever locking/unlocking the driver's door with the key. It seems to be wearing quite a bit to the point it now require a fair bit of pressure to get it in properly and is quite notchy, requiring a bit of wiggling to get it in right (passenger door/rear door, key slides in and out no problem).
As it's less than 2 years old, is this covered on warranty?
(P.S. tried explaining without sounding like a scene from a Carry On film but failed miserably) https://instagram.com/bentheoandrews
Post #605548 28th Feb 2017 4:20pm
ericvv
Post #605550 28th Feb 2017 4:26pm
Farmerben
Post #605555 28th Feb 2017 5:11pm
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
it may simply need lubricating. 1953 80"
1987 mini city e
2011 90"
Post #605650 28th Feb 2017 11:17pm
Shax
England 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Try a squirt of dry graphite lock lubricating powder... Don't use WD40 or any wet oils...
ebay item : eBay Item No. 322416759235 or similar should do the trick... ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
^^_-^-_^-^_^^^^^--^^^^
PAUL
G7ALW 14.200 USB
26FB458 / 27.275 SSB
Post #605939 1st Mar 2017 11:59pm
Cuthbert
ericvv wrote:
If it fails it should be covered by the factory 3 years warranty. No reason why it would not be.
Eric
These locks are not high quality items - they tend to freeze up in winter, the protective 'flap' that is supposed to stop dirt getting in when you remove the key seizes easily. As the OP has found - the smooth and reliable operation of a key gliding in and out of a lock is a sensation that Land Rover's procurement specialists dismissed as unnecessary.
If you get a lock (or locks) replaced under warranty - you may end up with several different keys! I'll second the views of 'Shax' - but be aware you might end up with dirty pockets (from the graphite on the keys) for a few weeks after you apply it to the locks.
Yet another 'feature' of Land Rover ownership - you pay top dollar for a vehicle that is assembled using some of the cheapest parts available from a global parts bin.
Post #606569 4th Mar 2017 12:05am
John-1030
Belgium 2013 Defender 90 Puma 2.2 HT Tamar Blue
Hi,
I have the same problem with my 2013 90 hardtop
Dry graphite is an effective and cheap fix.
John
Brussels Belgium
Post #610310 18th Mar 2017 4:49pm
MR_JAMES
which this chap he seems quite knowledgeable!
 1953 80"
1987 mini city e
2011 90"
Post #610428 18th Mar 2017 10:10pm
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
I had to go full hooligan on mine today to remove the passenger side lock and door due to the fact the lock had seized, surely there is a 3rd party company which better quality locks for the defender?
Post #610433 18th Mar 2017 10:22pm
Farmerben
Well stealers loosened mine up when they were robbing me of �800 and a wiper blade. Saved me getting my hands covered in lube. https://instagram.com/bentheoandrews
Post #610453 18th Mar 2017 11:50pm
