![]() | Home > Puma (Tdci) > Driver Door Lock Barrel Warranty? |
Farmerben Member Since: 16 Jan 2017 Location: Herefordshire Posts: 607 ![]() ![]() ![]() |
As my 2015 defender doesn't have any of this fancy shmancy remote central locking, I'm forever locking/unlocking the driver's door with the key. It seems to be wearing quite a bit to the point it now require a fair bit of pressure to get it in properly and is quite notchy, requiring a bit of wiggling to get it in right (passenger door/rear door, key slides in and out no problem).
As it's less than 2 years old, is this covered on warranty? Cheers (P.S. tried explaining without sounding like a scene from a Carry On film but failed miserably) https://instagram.com/bentheoandrews |
If it fails it should be covered by the factory 3 years warranty. No reason why it would not be.
Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 263 ![]() ![]() ![]() |
it may simply need lubricating. 1953 80"
1987 mini city e 2011 90" |
Shax Member Since: 05 Oct 2010 Location: London Posts: 391 ![]() ![]() ![]() |
Try a squirt of dry graphite lock lubricating powder... Don't use WD40 or any wet oils...
ebay item : eBay Item No. 322416759235 or similar should do the trick... ... ,-------, .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
John-1030 Member Since: 21 Mar 2015 Location: Brussels Posts: 6 ![]() ![]() ![]() |
Hi,
I have the same problem with my 2013 90 hardtop Dry graphite is an effective and cheap fix. John Brussels Belgium |
which this chap he seems quite knowledgeable!
1953 80" 1987 mini city e 2011 90" |
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 ![]() ![]() ![]() |
I had to go full hooligan on mine today to remove the passenger side lock and door due to the fact the lock had seized, surely there is a 3rd party company which better quality locks for the defender?
Well stealers loosened mine up when they were robbing me of �800 and a wiper blade. Saved me getting my hands covered in lube. https://instagram.com/bentheoandrews
