Home > Maintenance & Modifications > Lidl....for the Puma
spudfan
Ireland
Thinking of getting one of these for doing a gearbox oil change on the Puma.
https://www.lidl.co.uk/en/Non-Food-Offers.htm?articleId=1723
They also have a battery charger with jump start facility for £34.99.
Both from Monday 20th. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #610308 18th Mar 2017 4:45pm
Buz
United Kingdom 1987 Defender 90 200 Tdi HT Barolo Black
Does yours not come with a sump plug as standard?
Surely its better using the drain plug to check whats in the bottom of the sump, that shouldn't be?
Post #610342 18th Mar 2017 7:05pm
spudfan
Ireland
For putting it into the gearbox. The draining part is easy, it's the refilling that is a little awkward. 1982 88" 2.25 diesel
Post #610344 18th Mar 2017 7:07pm
roel
Does it also pump EP90? For the transfer box and axles? Roel
2003 90 Td5 (2009-now)
Post #610365 18th Mar 2017 7:53pm
spudfan
Ireland
That's my intention.. Mr. Green 1982 88" 2.25 diesel
Post #610377 18th Mar 2017 8:17pm
williamthedog
When I change the oil in the gearbox I push a pipe into the filler , thread it above the chassis ,up to about door level then squeeze oil out of the bottles straight into the gearbox.
Any left in the pipe is minimal,takes about 10minutes to do Thumbs Up
Post #610392 18th Mar 2017 8:44pm
spudfan
Ireland
I usually remove the cubbybox, then the inspection plate and gravity fill through the opening but I'm going to give this pump a go, if I'm in time to get one. 1982 88" 2.25 diesel
Post #610394 18th Mar 2017 8:49pm
roel
I have a hand pump and with the small original suction hose It hardly pumps the EP90. I have put a bigger suction hose on and that works but not as good as MTF with the original small hose. And the hoses in the picture are not a big diameter. Shocked Roel
Post #610563 19th Mar 2017 3:26pm
MartinK
That looks a great idea. I used a garden sprayer which worked well. This device looks even easier! Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #610587 19th Mar 2017 4:51pm
spudfan
Ireland
If it works great.....if not it'll hardly break the bank. If I manage to get one I'll give it a trial run and let you know how it works out. 1982 88" 2.25 diesel
Post #610594 19th Mar 2017 5:29pm
