![]() | Home > Maintenance & Modifications > Lidl....for the Puma |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4812 ![]() ![]() |
Thinking of getting one of these for doing a gearbox oil change on the Puma.
https://www.lidl.co.uk/en/Non-Food-Offers.htm?articleId=1723 They also have a battery charger with jump start facility for £34.99. Both from Monday 20th. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
For putting it into the gearbox. The draining part is easy, it's the refilling that is a little awkward. 1982 88" 2.25 diesel
Does it also pump EP90? For the transfer box and axles? Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
That's my intention..
![]() 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 ![]() ![]() |
When I change the oil in the gearbox I push a pipe into the filler , thread it above the chassis ,up to about door level then squeeze oil out of the bottles straight into the gearbox.
Any left in the pipe is minimal,takes about 10minutes to do ![]() |
I usually remove the cubbybox, then the inspection plate and gravity fill through the opening but I'm going to give this pump a go, if I'm in time to get one. 1982 88" 2.25 diesel
I have a hand pump and with the small original suction hose It hardly pumps the EP90. I have put a bigger suction hose on and that works but not as good as MTF with the original small hose. And the hoses in the picture are not a big diameter.
![]() 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2666 ![]() ![]() ![]() |
That looks a great idea. I used a garden sprayer which worked well. This device looks even easier! Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
If it works great.....if not it'll hardly break the bank. If I manage to get one I'll give it a trial run and let you know how it works out. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
